I'm trying to use the printf family of functions in C18 for a PIC18F26J50. In my system, the output should go through the UART and show up in RealTerm. Here is my approach:
  1. I initialized CPU clock, UART and GPIO before doing anything else. The main test code is a very simple one:
VOID main( VOID )
    char s[STR_SIZE];
    memset( s, 0x00, sizeof(s) );
    strcpypgm2ram(s, "1234567890\n0987654321");
    clockInit();
    uartInit(BAUD_115200);
    ledAliveInit();
    fprintf( _H_USER, "%s", s );
    while( 1 );
  1. I initialize and use the UART as follows (please, note that I implemented the _user_putc function as required by the library):
#include <p18cxxx.h>
#define UART_READ       0
#define UART_WRITE      1
PRIVATE UINT32 speed_[] = {19200, 38400, 57600, 115200};
PRIVATE UINT16_VAL getBrgValue_( const UINT8 baud )
    UINT16_VAL value;
    value.Val = (UINT16)((CLOCK/(4*speed_[baud])) - 1);
    return value;
PRIVATE VOID uartEnableWrite_( VOID )
    LATAbits.LATA2 = UART_WRITE;
PRIVATE VOID uartEnableRead_( VOID )
    LATAbits.LATA2 = UART_READ;
VOID uartInit( const UINT8 baudRate )
    if( (baudRate >= 0) && (baudRate <= 3) )
        UINT16_VAL brgValue;
        // disables analog-to-digital conversion pins
        // (enables digital IO on all AD pins)
        ANCON0              = 0x1F;
        ANCON1              = 0x1F;
        ADCON0bits.VCFG1    = 0;
        CM1CONbits.CON      = 0;         // disables comparator
        //Configuration TX and RX pins
        TRISCbits.TRISC6 = DIGITAL_OUTPUT;
        TRISCbits.TRISC7 = DIGITAL_INPUT;
        // baud rate setup
        BAUDCON1bits.ABDEN  = 0;    // disable auto-baud
        BAUDCON1bits.BRG16  = 1;    // enable 16bit register for baud rate generator
        BAUDCON1bits.WUE    = 0;    // disable wake-up bit
        // baud rate calculation and loading
        brgValue    = getBrgValue_(BAUD_115200);
        SPBRG1      = brgValue.byte.LB;
        SPBRGH1     = brgValue.byte.HB;
        // TX setup
        TXSTA1bits.TX9      = 0;        // don't transmit 9th bit
        TXSTA1bits.SYNC     = 0;        // ASYNC mode
        TXSTA1bits.BRGH     = 1;        // high speed communication
        TXSTA1bits.SENDB    = 0;        // don't send 12-bit BREAK char
        RCSTA1bits.RX9      = 0;        // 8-bit reception
        RCSTA1bits.CREN     = 1;        // enables receiver
        // enables rs485 transceiver direction control
        TRISAbits.TRISA2    = DIGITAL_OUTPUT;
        RCSTA1bits.SPEN     = 1;        // enable serial port
        TXSTA1bits.TXEN     = 1;        // enable TX
PRIVATE VOID uartSendByteInternal_( const UINT8 b )
    while (!TXSTA1bits.TRMT);
    TXREG1 = b;
INT8 uartSendByte( const UINT8 b )
    INT8 rc = ERROR_SUCCESS;
    uartEnableWrite_();
    uartSendByteInternal_( b );
    uartEnableRead_();
    return rc;
VOID uartDeInit( VOID )
    PIE1bits.RCIE   = 0;
    PIE1bits.TXIE   = 0;
    RCSTA1bits.SREN = 0;
    RCSTA1bits.CREN = 0;
    RCSTA1bits.SPEN = 0;
    TXSTA1bits.TXEN = 0;
int _user_putc (char c)
    (VOID)uartSendByte( (UINT8)c );
    return c;
  1. When I run this code I get the following in RealTerm: printf
If I change the string, the result changes. I can't find the problem but my guess is that it is related to different "types" of memory (rom x ram) from the PIC being used incorrectly.
  • \$\begingroup\$ does it work at 9600 baud? \$\endgroup\$ – Marcus Müller Jun 15 '19 at 5:57
  • \$\begingroup\$ Did you even modify SPBRG directly? \$\endgroup\$ – jonk Jun 15 '19 at 6:12
  • \$\begingroup\$ No, it does not work at 9600bps. Yes, I did tried modifying SPBRG directly (I took some sample values from this page: nicksoft.info/el/calc/?ac=spbrg). I assumed that even in high speed modes, I could use slower baud rates but I'm not sure. \$\endgroup\$ – daniel.franzini Jun 18 '19 at 14:15
Looks like a baudrate mismatch, you don't show your clockInit() function so it's not easy to say. Maybe you can check with a scope to make sure your baudrate is correct.
And two more comments:
-Hardware: You don't mention anything about the serial port on your Windows PC. If you're using a USB-to-RS232 cable make sure it takes 3.3V logic. If it's TTL instead you need to add pull-up resistances on your RX and TX lines and activate the open-drain mode, according to the datasheet:
-Software: C18 is not my cup of tea, but I've used this minimum UART example written in XC8 from the Microchip forums with minor modifications:
#include <xc.h>
#include <stdint.h>
#include <stdbool.h>
#define _XTAL_FREQ 48000000UL
#define RS485_READ 1
#define RS485_WRITE 0
#define IOF_8MHz 0b111
#pragma config XINST = OFF
void clockInit(void);
uint8_t high8(uint16_t x);
uint8_t low8(uint16_t x);
void main(void) {
    clockInit();
    ANCON0 = 0x1F;
    ANCON1 = 0x1F;
    // enables rs485 write (output)
    TRISAbits.TRISA2 = 0;
    TXSTA1bits.BRGH = 1; // set BRGH bit
    TRISCbits.TRISC6 = 0;
    TRISCbits.TRISC7 = 1; // Rx1 set input
    BAUDCON1bits.BRG16 = 1; // set 16 bits SPBRG
    BAUDCON1bits.RCIDL = 1; // set receive active
    SPBRGH1 = high8(104); // set UART speed SPBRGH
    SPBRG1 = low8(104); // set UART speed SPBRGL
    /* Loop forever */
    while (1) {
        LATAbits.LATA2 = RS485_WRITE;
        TXREG1 = 0x55; // yes, send char
        while (!TXSTA1bits.TRMT); // Ready ?
        LATAbits.LATA2 = RS485_READ;
        __delay_us(100);
void clockInit(void) {
    // disables reference oscillator output
    REFOCONbits.ROON = 0;
    // device enters IDLE mode on SLEEP instruction
    OSCCONbits.IDLEN = 1;
    // system clock is from primary oscillator
    OSCCONbits.SCS = 0;
    // selects base frequency as 8MHz
    OSCCONbits.IRCF = IOF_8MHz;
    // wait until oscillator is running
    while (!OSCCONbits.OSTS);
    // low speed USB (6MHz clock)
    UCFGbits.FSEN = 0;
    // enable PLL
    OSCTUNEbits.PLLEN = 1;
uint8_t high8(uint16_t x) {
    return (uint8_t) (x >> 8);
uint8_t low8(uint16_t x) {
    return (uint8_t) (x & 0xFF);
  • \$\begingroup\$ This code is from a post I wrote to the Microchip forums. I'm glad it is being used elsewhere. \$\endgroup\$ – daniel.franzini Jun 19 '19 at 22:09
  • \$\begingroup\$ Well, that's a coincidence... I wonder why you went for C18 then. Have you tried this code for your current problem? What about the pull-up resistors? \$\endgroup\$ – Marcos G. Jun 20 '19 at 3:35
  • \$\begingroup\$ The original code I wrote was also for C18. Some guy ported it to xc8 and returned to me but at that time the problem was related with clock and I figured it out using the xc8 code and other answers as well. I use C18 because that is what I have avaliable and because I think xc8 is too expensive (avr-gcc is just free). Amazes me the fact we don't have production quality C compiler for PIC18. \$\endgroup\$ – daniel.franzini Jun 21 '19 at 14:21
  • \$\begingroup\$ No wonder PIC lost the lead they had back in the old days of ASM. I was never professionally involved with PIC and when I had I used CSC. These days I use XC8 free, is it really that bad with the free version compared to the paid license? I mean code optimization. On PIC16 I never had any issues. But I agree with you, the available of good tools is very important. \$\endgroup\$ – Marcos G. Jun 21 '19 at 14:47
  • \$\begingroup\$ I meant free tools, of course. I haven't tested xc8 free yet but reports say it is very very bad. \$\endgroup\$ – daniel.franzini Jun 21 '19 at 18:03
