Required is a timer circuit to switch on an LED with 2 time constants, when a switch is depressed as follows:
  • when switch is closed, light an LED 10 ~ 20mA
  • when switch is opened again, keep the LED on for approximately 5s more
  • then fade LED off for approximately 10s.
  • circuit voltage = 3v
  • assume a standard red LED , Vf =~ 1.8v
  • prefer to have maximize brightness
  • small SMD low leakage caps <~22uF
  • no ICs that consume continuous quiescent current; but accept minimum idle current (< 0.25uA @ 25'C)
I'd like to use a mosfet to minimize voltage drop and maximize brightness.
I think that it would involve some chain of transistors or mosfets that are held on by capacitors, but I can't figure out how to keep it on full brightness for the first 5s, as they would start to fade immediately as the voltage drains out of the capacitor.
  • \$\begingroup\$ What does "virtually no current" mean? I don't think we can design to that requirement. \$\endgroup\$ Jun 17, 2019 at 1:15
  • \$\begingroup\$ Design Rule # 1. Never specify component types unless absolutely necessary. ONLY give all a) Input b) function and Output specs... plus other major restrictions. Rule #2 when you specify the wrong parts read Rule #1 again. Ceramic has a leakage time constant less than 20 seconds. But that's OK. There's another way. REWRITE your question using a datasheet point form approach with ALL SPECS including environment and tolerances for time and voltage, cost and mechanical construction. Now! s'il vous plais! \$\endgroup\$ Jun 17, 2019 at 1:26
  • \$\begingroup\$ If you outline in simple point form all parameters and tolerances in next 1hr I will award 1 pt otherwise -1 pt. Others may agree. Thankyou \$\endgroup\$ Jun 17, 2019 at 1:32
  • \$\begingroup\$ How complex are you willing to go? Discrete, I see three NPN, one PNP, and one NFET which is in keeping with your capacitor limitations. \$\endgroup\$
    – jonk
    Jun 17, 2019 at 5:16
  • \$\begingroup\$ Are you not aware of the leakage time constants in capacitors especially ceramic? Show me one capacitor with a time constant in the range you want. ( I know what to expect, but I want you to look) again you specified ceramic when it is size, and function that is important. Film caps are the only ones with long Δt=C*ΔV/I_leak \$\endgroup\$ Jun 17, 2019 at 17:49
It looks like I found a solution highly dependent on the device parameters.
enter image description here Low leakage parts are the critical factor. Take careful selection of Ids @ Vt and Vgs
Two inversions are done: The 1st must have a gate threshold of << 1/3 to 1/2 of Vbat and not 2 to 4V. This is what causes decay on the 1st time constant.
  • hi-side mechanical switch,
  • low-side Nch (inv)
  • hi-side Pch (inv)
The critical factors in the selection of both FETS are:
  • the IDSS leakage current must be extremely low at Vgs near 0V.
    • Carefully select with Drain Resistor to result in a voltage drop less the next gate threshold.
  • the threshold Vt or Vgs(th) @ Ids is critical because this acts as the voltage comparator for the 1st stage and the gradient declining LED intensity for the 2nd.
  • Both have long time constants so capacitor leakage resistance at Vcap needs to be estimated for the ambient temp. Film caps are best but are low Dk large parts.
