I'm trying to create a sawtooth signal using low cost pasive and active components. This will allow me to compare it to an analog signal to output a PWM signal.
My sawtooth signal have to be at least 21kHz and I rely on this scheme:
showed in this youtube video : https://www.youtube.com/watch?v=2a1I1X3RV0g
My power supply for the circuit is 8.2V and the amplitude of the signal has to e the biggest possible. The problem is that I can't simulate on Simetrix a "pretty" sawtooth wave at 21kHz (see picture below)
And my second problem is that I have to connect a follower so i can put my sawtooth signal in a comparator.
Do you have any idea if those problem come from the simulation or it's just impossible to do that ? Or do you have any other circuit to create that wave ?
Thank you.
  • \$\begingroup\$ So what components do you believe you are unable to use? \$\endgroup\$
    Jun 18, 2019 at 15:25
  • \$\begingroup\$ I think you'd have a much better chance of success at this if you use a comparator set up with a lot of hysteresis instead of Q1 and Q2. Even if you get it working nicely at one temperature, by the time you get it working reliably over temperature and manufacturing variations with discretes, you're going to be into it for more BOM cost and board space than just using a comparator. \$\endgroup\$
    – TimWescott
    Jun 18, 2019 at 15:35
  • \$\begingroup\$ Can you please define your desired range of frequencies and minimum fall time on the sawtooth and precise Peak voltages ( which enable you to get near 0% and 100% PWM ) with tolerances hopefully??? Give it a SWAG if you don't know. Rise time is defined by 10 ~90% and/or use dV/dt (=Ic/C) Please. Did you know you can also use a triangle wave?? \$\endgroup\$ Jun 18, 2019 at 15:38
  • \$\begingroup\$ See square wave to sawtooth. The square wave itself is relatively easy to generate, these days. So the driver for the circuit is relatively trivial. However, it doesn't generate a voltage that peaks at the supply rail. So keep that in mind. (Also, our definitions of what's a sawtooth and what's a triangle wave may be at odds.) \$\endgroup\$
    – jonk
    Jun 18, 2019 at 15:58
Instead of generating a sawtooth wave. Why not just generate some wave and let a op-amp figure out the duty cycle?
So allow me to show you another circuit that I think is slightly easier to construct.
enter image description here Link to simulation
To the left there's just a simple oscillator that gives you a relatively clean sine wave. That is added together with a feedback loop. The feedback loop is trying to make the average of the PWM equal to the input.
For an input of 1 volt the outputs is a PWM with a duty cycle of 20%. 2 volts gives you 40% and etc. Due to the shape of a sine wave, the bottom and top is relatively flat, this means that if the input is near 0.1 volt or around 4.9 volt the output starts getting very dependent on the amplification of the transistor. A solution to this would be to cascade with yet another transistor and change the feedback loop slightly, set up a darlington configuration, add two transistors and keep the feedback. Or just go with any other answer that doesn't depend on a sinewave as the wave to compare against.
Update due to comment:
The name for this particular circuit? "PWM generator"? I've come up with this one myself. So I'll just call it what it is. A PWM generator. The oscillator used is one of hundreds of variants of a Colpitts oscillator with the twist that you let the output be its gate instead of its drain or source. To my understanding, any oscillator that uses two capacitors, one inductor that define the oscillation frequency and one or more transistors to make it oscillate is a Colpitts oscillator.
I think it will work with any logic level NMOS, as you can see in the simulation it is oscillating between ~3 and ~0 volts, that is because the threshold voltage of the NMOS is 1.5V. One NMOS that I've used for this setup is the AO3402 which is a logic level NMOS. The oscillation is almost identical to the image above.
My design was supposed to be as easy to modify as possible, with that said, it is very possible to make small tweaks so the output of the op-amp never has to go below 0V. Or for the output to be more "digital", as in generating a better square wave. Now, why didn't I show THIS circuit instead? Because then it's not as easy to modify, it's more difficult to understand, and you'll get angry because it might not work with your particular setup. Your setup which I have 0 clue about. I'm quite certain that you'll have to modify my circuit to make it fit your needs. Hence I showed you the basics of making it work.
  • \$\begingroup\$ @HarrySvensson Thank you for your answer, it's very interesting. Is there a name to this circuit ? So I would like to simulate it on simetrix, i choose the 2N3904 for the transistor because it has a beta of 100 but I don't know what reference to chose for the op amp and n-mosfet. I have trouble finding the right one for my application. Also, is it required to have a dual supply for the op amp ? I would like to use single supply in all my project. Thank you for your help \$\endgroup\$
    – Gragon
    Jun 19, 2019 at 7:40
  • \$\begingroup\$ @Gragon "but I don't know what reference to chose for the op amp and n-mosfet", reference, you're talking about specific type of NMOS and op-amp, right? I've named my favorite NMOS that I know will work in my answer (AO3402). For the op-amp, as you can see I've placed it in such a manner that it's job is very easy, it only needs to integrate. For this even a "lousy" LM358/LMV358 will work. I don't know if even the worst ol 741 op-amp will work, but I think it would. What I'm trying to say is, any op-amp will probably work. - I've edited my answer for a more detailed answer to your comment. \$\endgroup\$ Jun 19, 2019 at 12:37
I see your problems. Do I need a diagram to explain?
Your random level and frequency shift are due to a PNP Emitter follower not shown in your schematic which causes Vbc forward conduction from the negative voltage on C1. Because it (Q4 not shown) see almost -0.6V it is on the verge of conduction results in the consequences of your waveform.
Clamping that with a Schottky diode would compromise your amplitude.
So what do you do?
  • don't add a series R to invisible Q4 because Q1-c is a current source and that leakage will cause overshoot on the return stroke if you care(?). So it must be equal to or greater than the Early effect leakage resistance of Q1 for a pristine sawtooth. (which I won't bother to explain may be around >=100k) But maybe you don't need to clamp overshoot.
So change that invisible Q4 (and don't hide things from us again) to an Nch Enh.FET common source or a P ch Common Source. That will give you >5Vpp signal and the level shift will be determined by the Vgs(th) which unfortunately is very loose so that is not a great solution. ( there are many better solutions, but I tried to explain how to fix your signal integrity, not meet some undefined voltage and risetime specs.) Pch Vgs(th)=4V should give you 0.5 to 6V negative ramp sawtooth.
But you really ought to reconsider re-inventing the wheel, define your specs ( which all good designers do in their head or on paper) and then realize what is better, make or buy!! I do not see in either of your two similar questions any specs other than as big as possible at least 21kHz ( a nice VLF Navy channel)
My solution using transistors with fast recovery time.
My Mods
  • I now get a full rail to rail sawtooth to 8.2V by changing the resistor ratio to 10k:100K for the trigger to raise the trigger voltage.
  • I changed R bias Current source to a simple CC source with 2 diodes.
  • With lower bias currents I now had to reduce C to get 100kHz , but this is adjustable with the CC emitter bias resistor such that Ic= 0.35V/Re( 10k)
  • The voltage drop is not 0.7 but 0.35V, because I am only using Ic=35uA whereas you were using 4.5V or so.
Your problem
  • with no resistor on Q4-b and CB becoming forward biased. ( which I had to imagine that you had, even if it was obvious to some)
  • \$\begingroup\$ p.s. I did not watch the video link. Did I miss anything better? \$\endgroup\$ Jun 18, 2019 at 16:28
  • \$\begingroup\$ Falstad's javascript simulation. tinyurl.com/y2pu89q5 \$\endgroup\$ Jun 18, 2019 at 19:02
  • \$\begingroup\$ Thank you for explaining me what's wrong with my circuit! How you writed make things easier to understand. You did not miss much from the video as you already understood how the circuit is working. I did not have an invisible Q4 as you said but a follower, it allowed me to connect my signal to a comparator, otherwise my signal went to 0. I'm trying to simulate your circuit as i allow me to have a rail to rail sawtooth which is better for me but the output i can't output the signal. It's the same as the one on falstad. Do you think it's the software simetrix not working ? \$\endgroup\$
    – Gragon
    Jun 19, 2019 at 8:31
