I am working on a voice recording application. The circuit simply has microcontroller, flash memory and mems digital microphone.
What are the advantages of using a stereo microphone on the quality of sound? If necessary, how should I position these two microphones?
The application does not require localization, beamforming similar complex works, just simple sound recording.
  • \$\begingroup\$ What makes you think you might need a stereo microphone? Have you tried using a mono microphone? \$\endgroup\$ Jun 18 '19 at 19:44
  • \$\begingroup\$ Because it is very common in smartphones,laptops or headphones. I want to understand whether it is used to improve quality. \$\endgroup\$ Jun 19 '19 at 13:40
  • \$\begingroup\$ Are you sure you understand what stereo audio is / means? \$\endgroup\$
    – Transistor
    Jun 20 '19 at 20:32
  • \$\begingroup\$ As i understand, there're 2 physical mics on the device(called right and left), data acquiring over these 2 channel and doing some processing like mixing with software, the actual sound is taken. \$\endgroup\$ Jun 22 '19 at 12:44
The advantage of a stereo microphone (or two mono microphones) is that it is possible to record in stereo for reproduction of a stereophonic image with sound sources located in the audio panorama. There is no advantage in fidelity of signal or signal to noise ratio.
Position them to get the effect you require. This is a broad subject so I will not attempt to answer it here as there is plenty of information on the web.
  • \$\begingroup\$ "There is no advantage in fidelity of signal or signal to noise ratio." - Not always correct: You can use two microphones to do beam forming, increasing relative sensitivity in one direction while decreasing in another. \$\endgroup\$
    – JimmyB
    Jun 20 '19 at 14:19
