I own a really bright led lamp that I want to dim. It is powered by a constant current power supply that can supply 37mA between 11V to 17V. If my lamp is connected the voltage settles at 13.58V.
enter image description here Please note, that there are more than four LEDs in unknown wiring in this lamp. I only drew four of them as illustration.
With a bench powersupply I determined, my desired brightness is reached at 1mA where the voltage drops to approximately 12.7V. To limit the current to 1mA while still using the constant current source I've added a parallel resistor like this:
For some reason this wont work. The voltage drops to 2.7V, the current on the branch with the resistor is 7.28mA, and the current on the branch with the led lamp is immeasurably small.
Is there something I'm missing? Or is there another possibility to dim the LEDs besides PWM? I thought abouth changing the sense resistor of the power supply but I don't really want to mess with the power supply.
    \$\begingroup\$ Your current source looks backwards. and you'll have to know something about the configuration of the LED's (series or parallel) to make any determination of the current. Ideally you'll need a V-I curve \$\endgroup\$
    – Voltage Spike
    Jun 18, 2019 at 20:12
    \$\begingroup\$ Note that when you use the CircuitLab button on the editor toolbar you don't need an account and editable schematics are saved in your post. (This would enable any of us to invert your current source for you.) It also allows us to copy and modify the schematic into our answers. \$\endgroup\$
    – Transistor
    Jun 18, 2019 at 21:09
    \$\begingroup\$ An experiment: try throwing some diodes in series with your resistor. \$\endgroup\$
    – Aaron
    Jun 18, 2019 at 21:20
    \$\begingroup\$ A CC current source may be modified to adjust the value and dim it. But unless we know the design , that limits your options to shunting the current and wasting 0.5W \$\endgroup\$ Jun 18, 2019 at 21:42
    \$\begingroup\$ Your PSU might be upset at trying to start into a straight resistor load, 11v into 377ohms is 29mA, which might be OK, or might be too close to what it thinks is right. Anyhow, Transistor has the right answer, use a series resistor and let the CC source just go to its maximum voltage, everything then gets less hot than the shunt wasting power solution. \$\endgroup\$
    – Neil_UK
    Jun 19, 2019 at 4:58
Figure 1. LED I-V curves.
According to my Figure 1 a typical white LED could be expected to drop about 3.5 V at 37 mA. Four in series would drop 14 V which is in pretty close agreement with your 13.6 V measurement.
Accurate figures for low currents aren't often published but if my graph is any way accurate you should see a voltage drop of about 1.5 V at 1 mA or 6 V across the four in series. You're measuring 12.7 V so your LEDs don't match the graph. They appear to have a much more vertical I/V curve.
Your calculation looks pretty close as far as I can see so I don't know why it doesn't work.
A more efficient alternate solution would be to connect a series resistor to limit the current. The CC PSU will then rise to 17 V and you'll need to just find the series resistor value as you would with any constant voltage supply.
  • \$\begingroup\$ Sadly, it is impossible to add a series resistor to limit the current, because the power supply want's to stay at 37mA at any cost, even if it means, that the voltage needs to go up to 30 Volts and only pulses because it isn't capable of handling this current at this voltage \$\endgroup\$
    – xeetsh
    Jun 19, 2019 at 22:00
  • \$\begingroup\$ I guess the only option is to look at the sense resistor or use a completely different (maybe not current limited) power supply \$\endgroup\$
    – xeetsh
I asked this question, and this answer I am giving doesn't exactly answer the question I asked, but I solved my problem by getting rid of the constant current power supply and used an off-the-shelf power supply with fixed voltage and a current limiting resistor, which made it really easy to meet my requirements.
I've chosen a 15V Power supply and used a resistor in series with the LEDs:
R = V / I = (15 - 13.58) / 1mA = 1420 Ohm
PWM may cause current measurement errors and long wires can introduce inductive voltage/current errors.
I suggest you use a TO-220 transistor so it doesn’t get hot, and bias the base current with a Voltage control Rseries or a pot and series R to limit the base drive, in order to dim the LEDs . A voltage divider to 0.4V will turn off the transistor then bias to 1V with 1mA should shunt the collector and turn off the LEDs by choosing the right R ratios and values from Vdc.
This is using it as an active shunt load like your resistor except with short path control between source, control and load in a small loop area to minimize wire inductance. It is the rise time that can cause issues not the PWM rate which might be >>1000x higher bandwidth if running at 2kHz for e.g. If we had some idea of the circuit, I could be more exact.
