I have a problem with the understanding of the memory map of the STM32F446RE.
In the Datasheet is the system memory (0x1FFF0000 - 0x1FFF7A0F) 30,51kb big.
But in the AN2606 the system memory is only 29kb big. But why?
I calculated this way: (kibibyte refers to the answer from Elliot Anderson)
Datasheet:
AN2606:
Difference:
So if my calculation is correct, what is in the other 1,51kbyte or 2,247 kbyte?
Update: For those who are interested, I got an answer from ST.
The whole caluclation is in kB --> 1024Byte
The flash memory has an information block, which contains the option bytes, so the calculation doesn't add up.
