I'm trying to connect A4 to pin 5 in 6050 in the picture.
a4 to 5
When I click those with the net tool, it also connects A2, which is not what I need. If I use the delete tool and erase the junction, they are still connected. How can I just connect a4 to 5?
  • \$\begingroup\$ What a horrible component symbol. Drawing wires over components is never a good idea and makes for a very ugly schematic. \$\endgroup\$
    – DerStrom8
    Jun 20 '19 at 10:19
  • \$\begingroup\$ What software are you using? \$\endgroup\$
    – Jeroen3
    Jun 20 '19 at 10:37
    \$\begingroup\$ I would say you do it by fixing that component to not have connections inside the symbol. They should all be on the outside. \$\endgroup\$
    – hekete
    Jun 20 '19 at 10:52
  • \$\begingroup\$ Hi, this is eagle pcb by autodesk. Library is user contributed. I'm just figuring my way into electronics in general and found it, but had plenty of problems trying to connect. Will find how to edit symbol then! \$\endgroup\$
    – fran35
    Jun 20 '19 at 12:24
I'd recommend not to put a pin inside a component symbol, it will make the schematic unclear.
You can differentate between the component's pins by grouping them and spacing them, to increase readability.
E.g grouping all VCC pins at the top of the component symbol and GND pins at the bottom, skip a pin between below A0 and above A5, as shown below.
PS. I just edited OP's picture here and assumed a GND1 and GND2. It's not meant to be a correct implementation of OP's case, rather as illustration of grouping and spacing pins.
  • \$\begingroup\$ Thanks, will find how to edit symbols so I can use it, similar as you proposed. \$\endgroup\$
    – fran35
    Jun 20 '19 at 12:25
The reason it is connected to A2 is because you have A4 within the body of the part and go over A2.
As per KiCAD Library Convention
https://klc.kicad.org/symbol/s3/s3.5/
Pin connection points must be placed outside of the symbol
This isn't to work around limitations, this is for consistency and equally you have taken the trace to A2
