I'm VERY confused about saturation and calculating it.
As i increase the resistance of photo diode of opto-coupler (4N35) the resistance between collector and emitter increases too.
  1. How the resistance between collector and emitter of opto-coupler affects the transistor in a opto isolator circuit which is gonna run a relay or MOSFET ?
  2. What does current transfer ratio % means? for example 4N35 CTR is 100% while 4N28 is 10%. is lower better? [source]
  3. How fast can an opto-coupler turn on/off, is it suitable for PWM?
  4. What's the difference between this two schematics, why in first one the base pin of opto-coupler is also used?
sch1
sch2
if possible please explain somehow so a beginner like me can understand this subject.
    \$\begingroup\$ CTR is identical to hFE after the optical coupling of about 0.1% to 1% worst case is factored. Otherwise, it behaves like a transistor which, when saturated only has 10% of its maximum hFE when saturated. (drops towards 10% of its rated CTR) So more is better, too much with Darlingtons means it much slower. PWM? not enough current drive. \$\endgroup\$ Jun 21, 2019 at 0:53
  • \$\begingroup\$ Does that make sense??? I assume you know how a transistor works \$\endgroup\$ Jun 21, 2019 at 2:41
Nope. As you increase the current going through the photodiode, the current passed through the transistor increases. Resistance is a linear phenomenon, transistors and diodes are nonlinear.
How the resistance between collector and emitter of opto-coupler affects the transistor in a opto isolator circuit which is gonna run a relay or mosfet?
The diode is an LED; it emits light. The phototransistor responds to light as if it were current on the transistor base. The "resistance" you are talking about is the effect where more current is passed in the transistor as more light is emitted from the LED. This current can be used to switch following electronics, such as a transistor that powers a relay.
Output current = (CTR) * (input current). More is better.
Relatively slowly. It's in the data sheet. Whether it's suitable for PWM depends on the speed of your PWM.
It looks like the top schematic is supposed to be linear, with Vout going down as Vin goes up. The bottom schematic is just supposed to turn the relay on and off.
  • \$\begingroup\$ RE "Resistance is a linear phenomenon", that's an idealization, but generally not a physical reality. \$\endgroup\$
    – The Photon
    Jun 21, 2019 at 5:15
