I am looking to build an audio interface that can also use real-time DSP to process audio coming from (most important) and going into the host.
After some research, I have been zeroing in on the xCORE-200 Multichannel Audio Dev Kit but want to make sure it is the right kit for my intended purpose.
here is a link to a commercial product that is in line with what I'm thinking of doing: https://www.uaudio.com/audio-interfaces/arrow.html
The main important thing about this device from Universal Audio is that it allows the user to use real-time effects on the audio coming from the host, thus saving the host from having to do all the work which is ultimately what I would like to do with my own C/python based effects that I've been writing.
closed as too broad by Elliot Alderson, RoyC, Voltage Spike, JYelton, Brian Carlton Jun 28 at 17:34
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ just a thought: i wonder if a GPU in a video card could be used to process audio data \$\endgroup\$ – jsotola Jun 21 at 3:16
  • \$\begingroup\$ @jsotola A GPU is great for parallel things, audio is very serial. I think just using a thread on the CPU would be simpler. GPU would make sense if he'd use some FFT techniques, something like overlay-save method. Oh well, I guess it depends on how/what OP actually wants to do with his audio. \$\endgroup\$ – Harry Svensson Jun 21 at 6:03
  • \$\begingroup\$ @jsotola exactly what Harry said. Also, unless you're processing hundreds of channels: for most things you'd want to do to real-time audio, your CPU is not going to even remotely have to break a sweat. It'd be really no use at all to use a GPU for that kind of workload. \$\endgroup\$ – Marcus Müller Jun 21 at 6:05
    \$\begingroup\$ Hi Steve! I think the project is very interesting, even without a purpose, but what exactly is the reason you want to safe your host computer from having to do the audio processing? As someone who's usually involved in real-time processing of signals on PC-type hardware, I can assure you that audio rates are really pretty benign and the kind of specialized processing hardware that can solve a problem that a PC couldn't would be pretty large indeed. \$\endgroup\$ – Marcus Müller Jun 21 at 6:09
  • \$\begingroup\$ The xCORE things are still pretty cool, simply because they can do things like building beamforming microphone arrays that look like normal microphones to a PC, so that you don't need special software on the PC – that's convenient from a user's perspective, not technically sensible. \$\endgroup\$ – Marcus Müller Jun 21 at 6:09
