I have to calculate current gain of the following circuit and to model it in Spice. I arbitrarily set Is = 0.0002 A: enter image description here Here are the results provided by LTSpice: enter image description here Also, in order to find an equation for current gain, my first idea was to transform Is and its parallel 5k resistor to a combination of voltage source (Vs = Is*5000 Ohm = 1V) and series 5k resistor. In this case the voltage at inverting input is Vy = Vx = 0.33*Vout, and the output voltage itself can be found according to following equation: (Vs - Vy)/5000 = (Vy - Vout)/20000. enter image description here Strangely, the results provided by LTSpice become quite disturbing when I increase the voltage to 2V (or current to 0.0004 A): enter image description here The same happens when I increase the value of 5k or 2k resistors. As you can see, I had a good luck arbitrarily choosing Is value as 0.0002 A. Otherwise, I could have very hard times. In general, if I keep all the resistors as they are and don't increase the current above 0.0004 A, then the output voltage can be calculated following these equations:
(5k*I1 - 1/3Vout)/5k = (1/3Vout - Vout)/20k;
6R*Is = Vout;
6*5000*0.0002 = 6 V;
My question is: how to correctly select voltage/current source and resistor values in order to avoid op-amp saturation?
  • \$\begingroup\$ How did you get the \$2\:\text{V}\$ for \$V_3\$? \$\endgroup\$
    – jonk
    Commented Jun 24, 2019 at 7:05
    \$\begingroup\$ @jonk , I mistaped. And it works! \$\endgroup\$
    – tenghiz
    Commented Jun 24, 2019 at 7:15
  • \$\begingroup\$ You are good, then! \$\endgroup\$
    – jonk
    Commented Jun 24, 2019 at 7:28
  • \$\begingroup\$ @jonk, please, can you take a look once again on my question? \$\endgroup\$
    – tenghiz
    Commented Jun 24, 2019 at 7:44
  • \$\begingroup\$ The opamp in your diagram isn't stable. If the output were to slightly rise, for example, this would increase the voltage at the (+) input node. But this would then cause the opamp to raise its output voltage. Which would increase the (+) input node, still more. It will "hit the rails," in this arrangement. If you hook up the \$R_3\$ and \$R_4\$ divider node to the (-) input, instead, then this aspect of the problem is fixed. \$\endgroup\$
    – jonk
    Commented Jun 24, 2019 at 8:24
If you solve the circuit, you'll find the reason why it's not stable:
\$V_+\$ and \$V_-\$ being the positive and negative terminal of the opamp
$$ V_+ = V_{out} \frac{R_4}{R_3+R_4} $$ $$ V_- = (V_{out}-V_3) \frac{R_1}{R_1+R_2} + V_3 $$ $$ V_{out} = A (V_+ -V_-) $$
$$ V_{out} = A (V_{out} \frac{R_4}{R_3+R_4} - (V_{out}-V_3) \frac{R_1}{R_1+R_2} - V_3 ) $$
$$ V_{out} = A V_{out} (\frac{R_4}{R_3+R_4} - \frac{R_1}{R_1+R_2}) + A V_3 (\frac{R_1}{R_1+R_2} - 1) $$
$$ \frac{V_{out}}{A} - V_{out} (\frac{R_4}{R_3+R_4} - \frac{R_1}{R_1+R_2}) = V_3 (\frac{R_1}{R_1+R_2} - 1) $$
$$ \lim_{A \to \infty} \frac{V_{out}}{A} - V_{out} (\frac{R_4}{R_3+R_4} - \frac{R_1}{R_1+R_2}) = V_3 (\frac{R_1}{R_1+R_2} - 1) $$
$$ - V_{out} = V_3 \frac{ (\frac{R_1}{R_1+R_2} - 1) }{ (\frac{R_4}{R_3+R_4} - \frac{R_1}{R_1+R_2}) } $$
$$ - V_{out} = V_3 \frac{ R_2 }{ (\frac{R_4(R_1+R_2)}{R_3+R_4} - R_1 ) } $$
$$ - V_{out} = V_3 \frac{ R_2(R_3+R_4) }{ (R_4(R_1+R_2) - R_1(R_3+R_4) ) } $$
$$ V_{out} = - V_3 \frac{ R_2 R_3 + R_2 R_4 }{ R_4 R_2 - R_1 R_3 } $$
  • \$\begingroup\$ Where do these equations come from? \$\endgroup\$
    – tenghiz
    Commented Jun 24, 2019 at 8:40
  • \$\begingroup\$ From your 3rd or 4th posted schematic. \$\endgroup\$
    – Huisman
    Commented Jun 24, 2019 at 8:41
  • \$\begingroup\$ I mean, where does the idea to calculate separately the voltages for op-amp inputs and then to calculate a limit comes from? I use "Electric circuits" of Alexander/Sadiku and had no idea of this method. \$\endgroup\$
    – tenghiz
    Commented Jun 24, 2019 at 8:46
  • \$\begingroup\$ I can't remember. I'll check up my old textbooks and provide a reference. But I might as well have made up the technique myself. \$\endgroup\$
    – Huisman
    Commented Jun 24, 2019 at 8:51
