I have an FT232R chip hooked up to my oscilloscope with the TX and RX pins joined. I'm sending characters directly to it via Putty. The logic levels I am seeing are 5V low and 0V high. I thought the output of this chip was TTL (i.e. 0V low and 5V high)? Am I missing something?
UART communication uses positive logic. In TTL, logic 1
is 5V, logic 0
is 0V. However, in UART, the idle, no data state is 1/HIGH, not 0/LOW. What you are seeing here is not inverted logic level, but simply an idle UART line.
The Wikipedia article on Universal asynchronous receiver-transmitter has a good explanation.
Data framing: The idle, no data state is high-voltage, or powered. This is a historic legacy from telegraphy, in which the line is held high to show that the line and transmitter are not damaged. Each character is framed as a logic low start bit, data bits, possibly a parity bit and one or more stop bits. In most applications the least significant data bit is transmitted first.
For completeness, here's an example. I'm sending ASCII character "U" (01010101
) via UART, 1 start bit, 8-bit data, no parity, 1 stop bit, 9600 baud.
On an oscilloscope, you will see the following waveform. Because the least significant data bit is transmitted first, binary digits of ASCII U
is reversed.
active
levels ... for example an active low means that 0V = logic1
\$\endgroup\$ – jsotola Jun 24 '19 at 19:30
