I try to design a board with an ARTIX-7 FPGA. There is a big question that which pin of FPGA should I put an oscillator? I inspected a document about clocking the 7 series xilinx FPGA (7 Series FPGAs Clocking Resources ) but I still don't know what should I do, because I saw a design of a kintex-7 and is had been put various oscillator with different frequancy.
What is the difference between MRCC and SRCC pins?
I'm thankful if someone can help me!
You can drive a clock into any CC (clock-capable) pin and use it as a GCLK or feed to a PLL or MMCM block.
There are special uses for some clocks, for example to implement memory interfaces, that have local low-skew local distribution in addition to driving a global net. That’s where MRCC and SRCC come in. MRCC inputs are Multi-region. SRCC are single-region.
The diagrams in the doc you linked explains SRCC and MRCC in more detail: https://www.xilinx.com/support/documentation/user_guides/ug472_7Series_Clocking.pdf#G4.319704
