I am building a system of detectors which are referenced to independent floating grounds. The maximum voltage between each stage is 2kVDC. So I need isolated supplies which can operate continuously at this voltage. I found these Mean Well supplies.
RSD-30G-5 VIN: 9-36V VOUT: 5V RSD-30G-12 VIN: 9-36V VOUT: 12V Both are 30W
The data sheet reads:
WITHSTAND VOLTAGE Input-Output: 4KVDC Input-Frame Ground:2.5KVDC Output-Frame Ground:2.5KVDC
I looked further but I cannot be totally sure the supply wont get shorted in a continuous 2kVDC use. I wanted to know if anyone had a different recommendation regarding the power supply or any thought on using these power supplies at 2kVDC.
I contacted the supplier to clear the rated voltage for continuous operation.
The maximum voltage a detector can go is 2kVDC.
In this link you can find the datasheet and the report of the tests conducted on the device.
