In Atollic TrueSTUDIO I open an empty project without any settings.
#include "stm32f4xx.h"
#include "stm32f4_discovery.h"
int main(void)
  while (1)
void EVAL_AUDIO_TransferComplete_CallBack(uint32_t pBuffer, uint32_t Size){
  /* TODO, implement your code here */
  return;
uint16_t EVAL_AUDIO_GetSampleCallBack(void){
  return -1;
and I observe the values in the CR register.
As seen in the photo it comes full of many bits. Even both HSE and HSI are active. Why? How?
I was just expecting HSI to be active because the reset value of this register is 0x83.
I also cannot reset the values of the bits when I add the RCC->CR=0x83; code to the program. Where am I making a mistake? (I adding the RCC->CR=0x83; code to the top of the while.)
Why are these settings pre-defined? Why doesn't the register change when I assign a value?
STM32F407xx RCC Register from Reference Manual:
Main() is not where the chip boots.
Find the reset interrupt handler. In there you will find it calls SystemInit, which does some basic setup and clocks for you.
