I'm implementing a WM8804 S/PDIF transmitter in a project I'm working on. The datasheet states that clocks from 10MHz - 27MHz are supported.
What crystal oscillator frequency should I look for in order to support 44.1kHz I2S output given a an input of 44.1kHz S/PDIF?
Edit:
It looks like 12MHz would work fine, given the info below:
Is this correct?
12 MHz is the default and only one that works in hardware mode so the PLL settings do not need to be altered.
