I have calculated the "active power" and the "the reactive" power of a system in dq axis in nonlinear form and I am doing system identification on this "nonlinear" plant as a MIMO system.
The problem I have is that the system identification works with "normalized models" and this causes that either there is a steady state error or no correct model is identified.
Is there any way to normalize a nonlinear plant (input/output) other than using the per unit parameters?
For best results, I suggest you need;
  • to convert to linear control e.g. 1/x, log x or at least piecewise linear control, then
  • have tuning weights for MIMO signals all of order unity and not higher order terms. e.g. position feedback for position control, current or acceleration feedback for likewise control.
  • use per unit variables for grid control
