-1
The internal generated voltage EA of a 2-pole, delta-connected, 60 Hz, three-phase synchronous generator is 14.4 kV, and the terminal voltage VT is 12.8 kV. The synchronous reactance of this machine is 4 ohm, and the armature resistance can be ignored.
The answer is given as: enter image description here
However, I do not understand why this is correct. Shouldn't VΦ be equal to VT/√3 = 12800/√3?
  • \$\begingroup\$ Why is this being down-voted? \$\endgroup\$ Commented Jul 1, 2019 at 20:43
    \$\begingroup\$ community here is like this, the reason stackexchange is dying. Down vote compensated. \$\endgroup\$
    – Deep
    Commented Oct 9, 2019 at 15:52
VΦ = VT because it's delta-connected.
