I am very new to Verilog, and I found the need to use "generate loops" to instantiate multiple hardware blocks. In this case, I am instantiating multiple "pe" blocks, a block which performs some simple arithmetic.
Code is shown below:
// intermediate signals
reg init_temp;
reg [D_W-1:0] in_a_temp;
reg [D_W-1:0] in_b_temp;
reg valid_D_in_temp;
genvar i, j;
generate
for (i=0; i<N; i=i+1) begin : pe_generate_i
for (j=0; j<N; j=j+1) begin : pe_generate_j
if ((i == 0) & (j == 0)) begin
valid_D_in_temp <= (pixel_cntr_A == M-1);
init_temp <= (pixel_cntr_A == M-1);
in_a_temp <= A[0];
in_b_temp <= B[0];
end else if (j == 0) begin
in_a_temp <= A[i];
valid_D_in_temp <= valid_D[i-1][j];
end else if (i == 0) begin
in_b_temp <= B[j];
end else begin
valid_D_in_temp <= valid_D[i][j-1];
init_temp <= gg;
end
pe pe_inst (
.clk(clk),
.rst(rst),
.init(init_temp),
.in_a(in_a_temp),
.in_b(in_b_temp),
.valid_D_in(valid_D_in_temp),
.out_sum(),
.out_b(),
.out_a(),
.valid_D(),
.init_out()
end
end
endgenerate
A syntax error arises in the first non-blocking statement: valid_D_in_temp <= (pixel_cntr_A == M-1);
Error:
# ** Error: (vlog-13069) systolic.sv(37): near "<=": syntax error, unexpected <=.
# ** Error: systolic.sv(37): (vlog-13205) Syntax error found in the scope following 'valid_D_in_temp'. Is there a missing '::'?
Can anybody suggest what the problem might be?
Thanks in Advance
