I am a bit confused about Impedance Matching for maximum gain and for maximum power transfer.
I knew that the conjugate matching between, for instance, an amplifier's output port and a load Zl, is given by the condition Zout = Zl*. Under this assumption, reflection at the interface between them will be zero.
Does this operation correspond to maximum gain condition, or maximum power condition, or both? Is there a difference between these two conditions?
