How or what are the constraints for deciding factors of envelope detector for AM?
As far as I know that charging time of the capacitor should be below 20T where T is periodic time of carrier and discharging should not give negative clipping, but I cannot see how to apply them.
Question 1
Question 2
Question 2
    \$\begingroup\$ Surely "below 20T where T is frequency of carrier" should read "where \$ T = \frac {1}{f} \$ where f is the frequency of the carrier? T would be then be the periodic time of the carrier which would make more sense. \$\endgroup\$
    – Transistor
    Jul 1, 2019 at 14:35
You've given no specification for modulation bandwidth versus carrier. The finest way to extract AM modulation is the synchronous detector using a mixer to combine the AM-signal and a fixed-amplitude fixed-phase same-frequency local oscillator that is phaselocked.
