When doing circuit analysis calculations I use the mathematical therefore symbol in my calculations and need to document my iterations to support my analysis. There is no ASCII code for the "therefore" symbol. There is a UNICODE U+2211 for it that doesn't work. I had to cut and paste the one in the title. Any pointers here?
closed as off-topic by Elliot Alderson, Voltage Spike, brhans, Renan, W5VO Jul 1 at 19:47
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – W5VO
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Do you want this: ∴? The internet seems to think this should be U+2234, not U+2211. (But I'm not getting the correct symbol using Alt+2234) \$\endgroup\$ – The Photon Jul 1 at 18:58
    \$\begingroup\$ Try Unicode U+2234 \$\endgroup\$ – StainlessSteelRat Jul 1 at 18:58
    \$\begingroup\$ This would be a stack overflow question. On this group you would type in \$\Rightarrow\$ to get \$\Rightarrow\$. \$\endgroup\$ – TimWescott Jul 1 at 18:58
    \$\begingroup\$ Definitely the wrong stack. fsymbols.com/keyboard/windows/alt-codes/laptop \$\endgroup\$ – Transistor Jul 1 at 18:58
    \$\begingroup\$ Just use the HTML entity ∴, which renders as ∴ \$\endgroup\$ – Dave Tweed Jul 1 at 20:02
Did you google it?
Because the symbol is not usually available on keyboards and within fonts, and to prevent compatibility issues, users have substituted a colon followed by a period (":.") to represent it.
Source: https://en.wikipedia.org/wiki/Therefore_sign
  • \$\begingroup\$ Yes but I did not find that one... Interesting, thanks! I actually looked at that and missed it. \$\endgroup\$ – SamR Jul 1 at 19:09
    \$\begingroup\$ Because I skipped over the freemasonry part as being of no interest. Strange they would put that there... \$\endgroup\$ – SamR Jul 1 at 19:20
On my iPad here with a BT keyboard.
™ alt-T.
Block quote. Alt-Q
∑ Alt W
FWIW
Mathjax
Basically use HTML for best or Mathjax which is “bound by \$ before and after \therefore
I am an EE, \$\therefore\$ I think outside the Ω box.
  • \$\begingroup\$ But no, therefore... Seems like I need to use :. but don't think others with a mathematical background will recognize it. \$\endgroup\$ – SamR Jul 1 at 19:37
  • \$\begingroup\$ Basically use HTML for best or Mathjax I think \$\therefore\$, I am \therefore \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jul 1 at 19:38
