Can you help me identify these two components? I cannot find information on them on the web. They appear to be ceramic filters of some kind.
Front of Component 1:
Back of Component 1:
Back of Component 1
Front of Component 2:
Back of Component 2:
Back of Component 2
  • \$\begingroup\$ They look like tantalum capacitors. \$\endgroup\$ – Michel Keijzers Jul 1 at 23:47
  • \$\begingroup\$ They are probably resettable fuses \$\endgroup\$ – gurghet Jul 2 at 0:02
    \$\begingroup\$ these cannot be filters, because they'd need a third/ground pin to dump rejected energy into. \$\endgroup\$ – analogsystemsrf Jul 2 at 2:05
They are resettable fuses, the big one is 600V for 160mA
https://www.distrelec.nl/en/radial-resettable-fuse-240-ma-ohm-littelfuse-trf250-120/p/16026991
The second is 30V for 1.6A
https://m.littelfuse.com/~/media/electronics/datasheets/resettable_ptcs/littelfuse_ptc_30r_datasheet.pdf.pdf
