I know how to power the load with the transistor when the base is "on".
But I sometimes need the opposite, to power the load when the base is "off". How to do that with transistors?
    \$\begingroup\$ You will fry your BJT without a base resistor. Think of the base-emitter junction as a diode. \$\endgroup\$
    – DKNguyen
    Jul 2, 2019 at 0:22
    \$\begingroup\$ what do you mean by base is off? \$\endgroup\$
    – jsotola
    Jul 2, 2019 at 1:06
  • \$\begingroup\$ @jsotola i meant when there is no current going in base \$\endgroup\$
    – Mirakul
    Jul 2, 2019 at 17:53
R2 acts as the base resistor for Q1 and feeds current to the base to keep it on unless you turn on Q2 to "short" Q1's base current.
