I made the following delay circuit. According to the simulation, it should take in the order of seconds for the relay to switch. Instead what I find (even by varying the resistance of the second stage) is that the relay switches on in about 100ms. In particular the tension on the capacitor C2 rises very quickly and in C3 almost instantaneously. Is there something I'm doing obviously wrong?
My input is 60Hz 12Vrsm and the 5ohm resistor is simulating a resettable fuse for 0.1A. The transistors (BC337-25) are rated for 45V C-E and the diode is a schottky with a 0.6V drop and rated for 40V breakdown.
delayer not working
It's hard to tell from your schematic what the voltages might be. What is the relay pullin voltage?
I imagine your simulation does not take into account the pickup voltage of the relay. For example, most 5V relays will actually pickup at about 3V or less, a 12V relay might pickup at 4-5V.
One potential way to ensure a higher pickup voltage on your C3 charge curve is to use a series Zener to offset the pickup voltage (though it's a kludge).
There are major problems with the schematic you have:
  1. The output stage has very limited base current drive, and any current drawn by the BJT base will tend to sop the cap charging.
  2. Even at low current requirements the half wave rectifier results in a large ripple voltage on C1. This may cause relay chatter as it picks up.
  3. The second RC stage provides very little time extension since it's charging along with the first stage.
I would not attempt to provide a timer in this fashion, but if you are trapped into this type of circuit for some reason, here is one that might work:
  1. Changing to a full wave bridge reduces the ripple.
  2. Increasing C1 reduces the ripple.
  3. M1/M2 act as a long tailed pair, and R3-R4 set the transfer point.
  4. D1-R6 provide a more rapid discharge for C2 when the power is off.
The waveforms are like this:
Notice there is still considerable ripple IMO, but much less than the half wave circuit.
A more reliable way to implement timing requirements like this is with a comparator (or even a 555 timer) to provide positive switching of the relay. Given the packages available, it would end up no more complicated than the above circuit.
  • \$\begingroup\$ Ok, my problem is not the relay pick-up voltage but the fact that the tension rises much more quickly than expected. Like 10x faster. But thanks for your observation \$\endgroup\$
    – gurghet
    Commented Jul 2, 2019 at 1:03
  • \$\begingroup\$ What is the relay-pickup voltage? Either the caps or the resistors are not the large values shown. Or transistors are wired wrongly. \$\endgroup\$ Commented Jul 2, 2019 at 1:57
  • \$\begingroup\$ @analogsystemsrf You don't know what a relay's pickup and dropout voltage are??? \$\endgroup\$ Commented Jul 2, 2019 at 3:09
  • \$\begingroup\$ What is the resistance of the relay coil? \$\endgroup\$ Commented Jul 2, 2019 at 5:56
  • \$\begingroup\$ I have verified via simulation that it should take several seconds for the relay to operate (or not at all if its resistance is too low). Therefore I suspect a wiring error or incorrect component values. If the transistors' Bases and Collectors were swapped the relay would operate in about 100ms. \$\endgroup\$ Commented Jul 2, 2019 at 6:29
