Unrecognised equipment It is normally quite noisy, but has gone silent.
The black box with white text in a circle is a week timer.
Not how there are Roman numerals: I - II - III - IV - V - VI - VII
which is 1 - 2 - 3 - 4 - 5 - 6 - 7 for the days of the week.
There are "6", "18" and "24" to indicate the hours of a day.
The green jumpers are the "ON" jumpers.
The red jumpers are the "OFF" jumpers.
These clocks are powered by a synchronous motor which rotates very accurately because it uses the mains frequency (50 Hz or 60 Hz) to rotate at the correct speed.
These motors have quite thin wires inside and sometimes these just break.
As this is all mains powered you should call an electrician to replace the clock.
  • \$\begingroup\$ @nuruvimama If I am reading the timer correctly, it looks like something is turned on at 06:00 and turns off at 00:00 every day. With the clock stopped in that position, it will now be permanently on. Do you know what it was controlling? \$\endgroup\$ – HandyHowie Jul 2 at 10:52
    \$\begingroup\$ @naruvimama the person above misspelled your name in the notification so I'm giving you a proper notification. \$\endgroup\$ – Hearth Jul 2 at 14:34
