I am trying out an H-Bridge inverter using GaN FETs at 140 kHz. The schematic is as follows. (In the experimental prototype, I used TI's LMG5200 and the load is connected via a full-bridge rectifier.
enter image description here The switching waveforms are enter image description here
The circuit works fine when it is not loaded. The output of the inverter: enter image description here
But when I load the inverter with the resonance LC circuit and the receiver, the output waveform becomes like this. The output voltage is not stable.
even in the LTSpice simulation, I can observe a similar waveform: enter image description here
But if I simulate at a higher frequency (by changing the value of the resonance capacitor), the output looks stable. See the below waveform at 640 KHz enter image description here
What am I missing here?
  • \$\begingroup\$ Why do you have output cap? Also why leg A and B are not 180 phased? \$\endgroup\$
    – jalaffo
    Jul 6, 2019 at 8:36
You are asking for trouble; the drive frequency is 140 kHz and your primary series resonant tuning is precisely 140 kHz therefore, the L and C act as a short circuit at the switching frequency. You need to run the primary circuit either from an output stage designed to handle the series resonance or use a different approach - maybe add a current limit resistor in series with C4(C2).
  • \$\begingroup\$ thanks, In fact, it will not be fully short-circuited. There will be a reflected impedance \$(\omega M)^2/R_L\$ in series with the ESR of the inductor. But at 140 kHz, it is extremely small. I understand that at a higher frequency, the reflected impedance will be higher and it makes the current lower. I may have to use larger L1 and L2 (so as the M) so that I can limit the current. The use of a series resistor is not an option due to high losses. What do you think? \$\endgroup\$
    – Pojj
    Jul 3, 2019 at 15:01
    \$\begingroup\$ I have done a similar job. I filtered the square wave to a sine and parallel tuned the primary. I don't know if this is possible for you. I was operating at 600 kHz FYI. \$\endgroup\$
    Jul 3, 2019 at 15:45
I encountered a problem when I was making a PCB board, the overcurrent phenomenon occurred in the full-bridge circuit, but the oscilloscope waveform under the driving circuit found that the two transistors on a bridge were not turned on at the same time, because the inductance of the PCB layout affected him.
