Today I tested a DC driver with a STM32 MCU. The schematic is like this:
I have a problem with the ENABLE Signal between the DRV8840 and the MCU.
When the DC Motor is disconnected, I toggle the EN pin and I can see +12V and -12V alternatively on the out pins of the DRV8840. Everything is OK.
When the DC Motor is connected. The MCU init is OK. When I set the EN Signal, the motor runs. But when I ask to toggle the EN Signal, it keeps 3.3V and the motor can't stop.
I can't toggle the EN Pin when the motor is running. WHY?
I don't understand why. My GPIO Pin is configured as Push Pull Output.
  • \$\begingroup\$ Can you verify that your code is still running when the failure occurs? Try connecting your SWD and see if some kind of fault has occurred. \$\endgroup\$ – Elliot Alderson Jul 3 at 12:32
  • \$\begingroup\$ Yes my code is still running without any errors. \$\endgroup\$ – VoltAd Jul 3 at 12:35
Ok I have the answer...
It was due to encoder interrupts. My motor is coupled with an encoder and when I disconnect the motor, I also disconnect the encoder. I tested my program with disabling the interrupt and it is ok.
