I'm doing a 3s audio.wav simulation on LTSpice with the following circuit (3 band pass filters and amplifiers):
In this example it's boosting the bass and attenuating the highs.
It loads the first second really fast and then it start to take a longer time:
When done amplifying the highs it gets stuck in 2s of the simulation.
The error I get is Fatal Error: Analysis: Time step too small; time = xxxxx,timestep=1.25e-15: trouble with u3:qx-instance q:u3:1. Or sometimes it's U6 that fails.
How can I solve this?
Thanks in advance!
Rser=0.1 Cpar=1m
to the supplies (builtin parasitics). Maybe alsoRser=1
to the signal source, as well. \$\endgroup\$
