Dell impression is 14". 14" is 1366x768. You risk get small image at left top coner of LCD 21". LCD 21" is 1920x1080. If MB support resolution 1920x1080 for LVDS - you get good image. I think no. Add LCD-cable (without LCD) to MB and check LVDS resolution 1920x1080.
You must connect:
- Four odd pair RXOC- RXOC+ RXO0+ RXO0- RXO1+ RXO1- RXO2+ RXO2+
(for your example LVDSA_DATA#0- to FR0-, LVDSA_DATA0 to FR0+, LVDSA_CLOCK to FCLKIN+, LVDSA_#CLOCK to FCLKIN- etc)
- Four even pair RXEC- RXEC+ RXE0+ RXE0- RXE1+ RXE1- RXE2+ RXE2+ (LVDSB_DATA#0_C to SR0M etc)
- Connect GND to pin 7,17,24 etc (and test that pinout is good)
- Connect LCD power supply (5 volts for LM230WF3).
Also... found and check LCD present signal. I do not found your "present" signal. Present signal usually connected to ground. Usually the cable connected present signal to GND directly.
If you have inverter - and powered inverter good - it's enouth to see image.
If you have LED matrix (your matrix is not LED) you must also connect VCC_LED to 12v, PWM_IN and PWM_EN to 3v3. May be you need found this pins at inverter. Case when invertor is not working and matrix work ok can exist.
The notebook MB in some cases not accepted alien displays. LVDS_DDC_CLOCK and LVDS_DDC_DATA signal is EDID. EDID "memory" describe the matrix. May be you need i2c flash rom. May be... connect 3v3,GND,LVDS_DDC_CLOCK,LVDS_DDC_DATA to old circuit of matrix (or path of matrix) of this notebook. If the resolution of screen and resolution of MB is different - you need change flash-bios program. It's not 100% warranty that all work ok. Good luck.
the LCD requires 5V and the motherboard supply only 3,3V. Maybe a
jumper though USB +5V could fix it?
No. You can: Add wire to 5v (found 5v at MB, usb may be no, USB can refuse alien power supply) else add DC-DC 12to5 to 12v of backlight. DMIC_CLK_C CAMERA and other pins can be NC.
P.S. I have connected Asus prime h310t to 17" LCD N173GE-L11 directly, I have one power button, and one power supply (12 - 19 v, i7-8700T+mem+MB+tinyHDD+fan+dispay = 1,5A*12v when 0-1% CPU). The thing mini-itx MB may be intrest you.(7-8th gen:GA-IMB370TN, GA-H310TN, Asus prime h310t r20, 10th gen: Asus Pro H410T, GA-IMB410TN - all mb support 1920x1080 1600x900 1366x768 resolution setup from bios). And gigabyte have also simular model.
