I have seen this rather simple circuit for end position detection of a DC motor drive mechanism. An infrared LED (V402) and a phototransistor (V401) are used as a light barrier.Infrared Position Detector
Can someone give me a hint concerning the circuit topology name and function of the additional BC856A (V403) PNP transistor in this circuit? (Is it a current amplifier?)
Isn't this circuit design very susceptible to ambient light and also temperature variation?
Edit1: Here is the simulation result of this circuit. It seems to have a current to voltage gain of 20V/mA.
    \$\begingroup\$ Have you looked up cascode or common base? Also, note that 20V/mA just happens to be what a 20k Ohm resistor achieves. \$\endgroup\$ – jonk Jul 5 at 7:15
  • \$\begingroup\$ It seems to me that T1 is always operated in the saturation region and thus is constantly switched on. So it has basically no function and the 20V/mA output is caused by the 20k Ohm resistor R1, right? \$\endgroup\$ – Stefan Wyss Jul 5 at 7:53
    \$\begingroup\$ It helps to keep the Vce of the detector BJT constant -- eliminating early effect issues. And no, it's not saturated until VM1 equals VF1, at which point it moves gradually into saturation. \$\endgroup\$ – jonk Jul 5 at 7:58
  • \$\begingroup\$ @jonk Ok, I think you got it right. The purpose of the BJT (V403/T1) is to keep the voltage across the photo transistor (V401) constant. This reduces the early-effect, i.e. it decouples the photo current from the collector-emitter (Uce) voltage. (Would you write this as an answer so I can give you credit for?) \$\endgroup\$ – Stefan Wyss Jul 5 at 13:57
  • \$\begingroup\$ I could. But Dave has done a yeoman's job already and spent more time thinking about the circuit than I did. I could provide some additional examples to help clarify a few things. But if you are happy with Dave's answer I'm fine with that. \$\endgroup\$ – jonk Jul 5 at 16:45
You made a good start by setting up a simulation. Unfortunately, your simulation is misleading you. There are two issues:
  • The phototransistor is not an ideal current source; instead, you should be modeling it as a current limiter. Putting a diode in parallel with it is one way to model this.
  • The circuit was undoubtedly designed for a supply voltage higher than 3V. 5V is much more likely.
Jonk's comment comes close to the answer — the transistor is functioning as an emitter-follower, with the emitter terminal held at roughly 2/3 the supply voltage plus a diode drop. This means that the voltage across the phototransistor is limited to slightly less than 1/3 the supply voltage.
While this will help with some dynamic effects, it's much more likely that it was done in order to meet a voltage rating limitation on the phototransistor.
  • \$\begingroup\$ Thanks for your insightful answer. Which way around would I have to place the diode? I can confirm that V_ON is always 3V (I got that from another part of the schematic). The photo transistor (V401) has a collector-emitter breakdown voltage of min. 5V. So the voltage rating limitation is off the table. \$\endgroup\$ – Stefan Wyss Jul 5 at 12:19
  • \$\begingroup\$ Think about it -- which way does the diode need to point in order to all "excess" current from the ideal source to flow through it and bypass the rest of the circuit? \$\endgroup\$ – Dave Tweed Jul 5 at 12:30
  • \$\begingroup\$ I do not get the point of this current limiter modeling of the phototransistor. Did you propose that for keeping the graph for VM1/VF1 right for currents in excess of 100uA? Don't you think we would rather need to add some internal resistance to the phototransistor for a better model? \$\endgroup\$ – Stefan Wyss Jul 5 at 12:40
    \$\begingroup\$ The point is, a phototransistor won't force current through an external circuit, while an ideal current source will -- and this will mess up your interpretation of the simulation results. \$\endgroup\$ – Dave Tweed Jul 5 at 12:58
