I'm trying to use I2C between an STM32F103C8T6 development board and an Arduino Uno.
However, I always get a HAL_BUSY error when I call HAL_I2C_Master_Transmit in the code below.
(I used 10K pullup resistors at SCL and SDA) on the STM32 side and a logic level converter between STM32 and Arduino.
How can I send messages from the STM32 to the Arduino?
int main(void)
  MX_I2C1_Init();
  char buffer[16];
  strcpy((char*) buffer,  (const char*) "Test 1");
  while (1)
      HAL_GPIO_TogglePin(GPIOC, GPIO_PIN_14);
      HAL_Delay(1000);
      if (HAL_I2C_Master_Transmit(&hi2c1, 8, (uint8_t *) buffer,  7, 1000) != HAL_OK)
          HAL_Delay(1000);
Settings (all default):
  hi2c1.Instance = I2C1;
  hi2c1.Init.ClockSpeed = 100000;
  hi2c1.Init.DutyCycle = I2C_DUTYCYCLE_2;
  hi2c1.Init.OwnAddress1 = 0;
  hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
  hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
  hi2c1.Init.OwnAddress2 = 0;
  hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
  hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
    \$\begingroup\$ Is the Arduino address '8'? \$\endgroup\$ – Long Pham Jul 6 at 14:40
    \$\begingroup\$ Yeah I know :) BTW, HAL I2C functions require left shifted address. \$\endgroup\$ – Long Pham Jul 6 at 15:04
    \$\begingroup\$ Maybe your problem is the same as this. \$\endgroup\$ – Long Pham Jul 6 at 15:47
    \$\begingroup\$ Try it without level shifters, all possible I2C pins are 5V tolerant on the STM32F1. Are the GPIO pins set to open-drain? \$\endgroup\$ – berendi - protesting Jul 7 at 19:37
    \$\begingroup\$ Did you initialise wire library in UNO with : wire.begin(0x8); \$\endgroup\$ – Meenie Leis Jul 8 at 6:38
