I'm new to embedded systems and I want to program a PIC12F675 for a project.
So, the idea is that there is a switch. If the switch is off, the microcontroller normally outputs a clock signal, which its frequency is controlled by a potentiometer. And if the switch is on, there is another button that I can push to output a pulse that lasts for 500ms and goes low again.
I wrote the code, but it seems to not be working correctly. Also I didn't code the potentiometer part because I don't know how, so it outputs a clock that it's frequency can't be controlled.
The problem:
When the switch is off (mode = 0), the clock doesn't work. However, when the switch is on (mode = 1), the clock works. It should be the other way around. Also, the pulse button doesn't work in either modes. Lastly, as I said before, I didn't code the potentiometer part because I don't know how.
So, could someone help me with this? Thank you.
Here's the config:
#pragma config FOSC = INTRCCLK
#pragma config WDTE = OFF
#pragma config PWRTE = OFF
#pragma config MCLRE = OFF
#pragma config BOREN = ON
#pragma config CP = OFF
#pragma config CPD = OFF
Here's the code:
#include <xc.h>
#include "config.h"
#define _XTAL_FREQ 4000000
void dClock(int delay){
    GPIO2 = 1;
    __delay_ms(delay);
    GPIO2 = 0;
    __delay_ms(delay);
void main(void) {
    TRISIO2 = 0; //output
    TRISIO3 = 1; //mode
    TRISIO5 = 1; //pulse_button
    char pressed = 0;
    GPIO2 = 0;
    while(1){
        __delay_ms(50);
        if(GPIO3 == 0){
            int delay = ADC_Read(); //Supposed to read analog value here
            dClock(delay);
        else{
            if(GPIO5 == 1 && pressed == 0){
                GPIO2 = 1;
                __delay_ms(500);
                GPIO2 = 0;
                pressed = 1;
            else if(GPIO5 == 0 && pressed == 1){
                pressed = 0;
    return;
Edit:
I edited the code and config, and everything is working fine. Now, I'm just still missing the analog input of the potentiometer.
    \$\begingroup\$ Why are you enabling MCLR as reset? \$\endgroup\$ – Spehro Pefhany Jul 7 '19 at 0:35
    \$\begingroup\$ When your switch is off, your PIC is reset and your code is not running because you enabled MCLR with #pragma config MCLRE = ON. \$\endgroup\$ – brhans Jul 7 '19 at 2:54
  • \$\begingroup\$ Thank you so much, guys. It works properly now. Just one thing is missing. How to get analog input from the potentiometer? \$\endgroup\$ – Ali Abo Shady Jul 7 '19 at 11:04
  • \$\begingroup\$ Here you find the answer youtube.com/watch?v=LFpSlw2EJ9E Example code drive.google.com/file/d/0B8iMbc-iQqlUbzFxWURKV0swTHM/view \$\endgroup\$ – G36 Jul 7 '19 at 11:13
    \$\begingroup\$ I did all the steps in the video, but the ADC_Read(0) function didn't work. I got this error: "Implicit declaration of function ADC_Read is not valid in C99" \$\endgroup\$ – Ali Abo Shady Jul 7 '19 at 11:36
The problem is here:
ADC_Read() is not a standard function supported by the xc8 compiler. You had to write it on your own.
Hint: Maybe you like to use the library mcc
