Lets say we want to create a generic t flip flop counter, the structure of this kind of counter is perfectly repetitive, and you can synthesize one with arbitrary length just using a for generate
however the bound for that for
and the length of the output is internal to the file, a constant, is there a way to sort of passing an argument when creating a component so as to define the length of the counter when creating the component instead of in the file?
here is the code of the counter i made
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
entity counterTst is
port(
enable: in STD_LOGIC;
clk: in STD_LOGIC;
rst: in STD_LOGIC;
output: out STD_LOGIC_VECTOR(3 downto 0)
end counterTst;
architecture rtl of counterTst is
constant COUNTER_LEN: integer := 4;
component t_ff is
port(
rst: in STD_LOGIC;
clk: in STD_LOGIC;
inp: in STD_LOGIC;
t: out STD_LOGIC
end component t_ff;
signal tin: STD_LOGIC_VECTOR(COUNTER_LEN-2 downto 0);
signal tout: STD_LOGIC_VECTOR(COUNTER_LEN-1 downto 0);
begin
T_CHAIN_GEN: for i in 0 to COUNTER_LEN-1 generate
START_POS: if i = 0 generate
FF0: t_ff port map(rst, clk, enable, tout(0));
end generate START_POS;
POS_1: if i = 1 generate
tin(0) <= tout(0) and enable;
FF1: t_ff port map(rst, clk, tin(0), tout(1));
end generate POS_2;
POS_N: if i > 1 generate
tin(i-1) <= tout(i-1) and tin(i-2);
FFX: t_ff port map(rst, clk, tin(i-1), tout(i));
end generate POS_N;
end generate T_CHAIN_GEN;
output <= tout;
end rtl;
