everyone. I'm new to embedded systems and I want to program a PIC12F675 for a project.
I have most of the code figured, and there is only one thing left. It's the analog input. I tried some tutorials, but they didn't work. They used the function "ADC_Read()" which isn't a standard function in XC8, which I'm using.
So can someone help me with this? Thank you.
The Config:
#pragma config FOSC = INTRCCLK
#pragma config WDTE = OFF
#pragma config PWRTE = OFF
#pragma config MCLRE = OFF
#pragma config BOREN = ON
#pragma config CP = OFF
#pragma config CPD = OFF
The Code:
#include <xc.h>
#include "config.h"
#define _XTAL_FREQ 4000000
void dClock(int delay){
    GPIO2 = 1;
    __delay_ms(delay);
    GPIO2 = 0;
    __delay_ms(delay);
void main(void) {
    TRISIO2 = 0; //output
    TRISIO3 = 1; //mode
    TRISIO5 = 1; //pulse_button
    char pressed = 0;
    GPIO2 = 0;
    while(1){
        __delay_ms(50);
        if(GPIO3 == 0){
            int delay = ADC_Read(); //Supposed to read analog value here
            dClock(delay);
        else{
            if(GPIO5 == 1 && pressed == 0){
                GPIO2 = 1;
                __delay_ms(500);
                GPIO2 = 0;
                pressed = 1;
            else if(GPIO5 == 0 && pressed == 1){
                pressed = 0;
    return;
  • \$\begingroup\$ Doesn't the datasheet share some insight on what to do? \$\endgroup\$ – Harry Svensson Jul 9 at 9:09
  • \$\begingroup\$ @HarrySvensson I don't know how to use the datasheet. I'm new to this and still learning. \$\endgroup\$ – Ali Abo Shady Jul 9 at 9:13
    \$\begingroup\$ Oh well, page 43 (chapter 7) is there for the taking. \$\endgroup\$ – Harry Svensson Jul 9 at 10:24
    \$\begingroup\$ I do not see any setup code for your ADC. You need to setup the ADC and TURN IT ON to be able to use it \$\endgroup\$ – Cerezo Jul 9 at 11:59
