I wrote a code that takes an analog input from a potentiometer and controls the frequency of a clock pulse. So, the idea is to increase the frequency when I increase the pot and decrease the frequency when I decrease the pot. It should change at a constant rate.
The problem:
When I change the pot, the frequency changes, but not in a constant rate. For example, when I increase the pot, the frequency may decrease and if I increase the pot more, it may increase again. And so on.Here are some examples of when I keep ONLY INCREASING the pot:
The Config:
#pragma config FOSC = INTRCCLK
#pragma config WDTE = OFF
#pragma config PWRTE = OFF
#pragma config MCLRE = OFF
#pragma config BOREN = ON
#pragma config CP = OFF
#pragma config CPD = OFF
The Code:
#include <xc.h>
#include "config.h"
#define _XTAL_FREQ 4000000
void delay(unsigned char freq){
for(int i = 0; i < (int)freq; i++){
__delay_ms(1);
void dClock(unsigned char freq){
GPIO1 = 1;
delay(freq);
GPIO1 = 0;
delay(freq);
void InitADC(){
ANSEL = 0x11;
ADCON0 = 0b00000001;
CMCON = 0x7;
VRCON = 0;
unsigned char GetADCValue(){
ADCON0 = 0b00000011;
while(GO_nDONE);
return ADRESL;
void main(void) {
TRISIO0 = 1; //analog input
TRISIO1 = 0; //output
TRISIO2 = 0;
TRISIO3 = 1; //mode
TRISIO5 = 1; //pulse_button
char pressed = 0;
GPIO1 = 0;
InitADC();
while(1){
if(GPIO3 == 0){
GPIO2 = 1;
unsigned char freq = GetADCValue();
dClock(freq);
else{
GPIO2 = 0;
if(GPIO5 == 1 && pressed == 0){
GPIO1 = 1;
__delay_ms(500);
GPIO1 = 0;
pressed = 1;
else if(GPIO5 == 0 && pressed == 1){
pressed = 0;
return;
Other than that, everything works fine. Could someone help me with that? Thank you.
CMCON = 0x7;
doing in the ADCinit() ? \$\endgroup\$ – Huisman Jul 9 at 19:47
