When I power my esp32 with an USB cable and check the readings of JSN-SR04 it shows correct and consistent readings. But when I connect esp32 and jsn with 5v from LM2596 12V input errors are not correct and sometimes consistent. Can anyone help me with this?
Either the voltage is not 5V, or it cannot supply the current or more likely there is an instability on the power rail. You need to check it with a scope. Also make sure you have all the recommended capacitors in place for smoothing the LM2596. My guess is residual spikes from the switching
| improve this answer | |
  • \$\begingroup\$ thanks for your reply. I dont have scope so I measured it with multimeter and the voltage is 5V. Esp is functioning normally, so I dont think there are any current issues. \$\endgroup\$ – user193395 Jul 10 '19 at 9:04
  • \$\begingroup\$ @ACSreedharReddy It's like ly to be high frequency spikes on the line. Try adding a 100n ceramic capacitor to the PSU output, or maybe 1uF ceramic \$\endgroup\$ – Dirk Bruere Jul 10 '19 at 10:22
  • \$\begingroup\$ Tried placing 100nF across lm2596 input. But could it did not help. \$\endgroup\$ – user193395 Jul 10 '19 at 11:02
  • \$\begingroup\$ Another to thing to mention is even connecting esp32 with usb and common grounding jsn and esp with input 12v ground the issue exists. \$\endgroup\$ – user193395 Jul 10 '19 at 11:16
