I have finished my schematic for an echo circuit using PT2399 IC as per the application circuit in datasheet. I have downloaded the part (including footprint) from snapeda.com and updated my Altium library. But I can't update the design to PCB. There's no option as 'Update PCB document' under the 'Design' tab to update the design to PCB. But it is showing for other projects I have done. I don't understand. Please help me, it's urgent.
  • \$\begingroup\$ At risk of insulting MegaMind (which is not my intention) but do you have a .PcbDoc setup in the .PrjPcb? And, is this "update PCB" function grayed-out or just not there? \$\endgroup\$
    – Steve
    Jul 10, 2019 at 13:00
  • \$\begingroup\$ Thank you so much Steve. Actually I'm new to this Altium. This is my first project besides a simple power supply which I did to learn this and it was done some time ago and honestly I forgot. Thank you sir. \$\endgroup\$
    – MegaMind
    Jul 10, 2019 at 13:25
  • \$\begingroup\$ No worries there MegaMind. I, was baptized-by-fire (no formal training) learning Altium so I understand the possible frustration/s. \$\endgroup\$
    – Steve
    Jul 10, 2019 at 14:19
Altium Designer is similar to, for example, Microsoft Visual Studio and other major development applications, in the sense that you can open a single document or an entire project (collection of related documents).
When you have just a PCB or schematic document open, Altium has no context for updating one from the other. If you have the project open — even if you only have one schematic within it actually open — then Altium 'knows' which PCB you want to update.
The file extensions of interest (per Altium 19) are:
  • PrjPcb = The entire project
  • PcbDoc = PCB
  • SchDoc = Schematic
(It may help to have file extensions shown.)
