9
I have a very basic circuit on a breadboard using an Arduino's 5V+Gnd to power a few LEDs. All the LEDs are from Sparkfun and rated at 2V/20mA, coming in Red, Green, and Yellow. I'm using 330 Ohm resistors but I also have much higher resistors like 10k and 330k Ohm for testing this issue.
Only one LED is being connected at a time using the individual lanes. Nothing is connected to the power and ground rails on the breadboard. Red, green, and even my white LEDs work great, but so far 5 yellow LEDs in a row have immediately burned. I double-checked wiring, moved wires and LEDs, and went all the up to a 330,000 Ohm resistor, but no luck with the yellows. Is this likely a bad batch of yellow or am I missing a key component?
EDIT: Here is the full board (the wires are complex because this will be an electronics puzzle in a game):
Photo of entire circuit
And here is with the other wires removed to show what's actually connected:
Photo of relevant circuit section
    \$\begingroup\$ Can you add a schematic and a photo of your board? \$\endgroup\$ – HandyHowie Jul 10 '19 at 14:16
    \$\begingroup\$ Burned? Caught fire? turned to dust? \$\endgroup\$ – Andy aka Jul 10 '19 at 14:21
  • 5
    \$\begingroup\$ If you're burning out LEDs on a 5V supply, with a 330 ohm resistor in series, then you must be wiring it wrong somehow. Most likely, the 330 ohm resistor isn't really in series with the LED. \$\endgroup\$ – Simon B Jul 10 '19 at 14:23
  • 4
    \$\begingroup\$ "After the smoke clears, check the wiring again" \$\endgroup\$ – Barleyman Jul 10 '19 at 14:25
    \$\begingroup\$ 99.999% sure you are wiring the resistor in parallel... If an LED is dying with 330k then the wiring needs to be looked at \$\endgroup\$ – JonRB Jul 10 '19 at 14:41
73
Those resistors aren't doing anything at all. All the pins in a row are connected together.
| improve this answer | |
  • 7
    \$\begingroup\$ There it is, I'm a dummy! Thank you. \$\endgroup\$ – Jonathon Irons Jul 10 '19 at 14:43
  • 5
    \$\begingroup\$ The human mind is a wonderful thing. It expects the row of terminals to be connected through in the bits it wants connected and open where it wants it open. I'm sure there's a psychology thesis in there somewhere. \$\endgroup\$ – Transistor Jul 11 '19 at 13:30
    \$\begingroup\$ @ Toby - The LED sacrificed itself to protect the Arduino output \$\endgroup\$ – DaveM Jul 11 '19 at 14:55
    \$\begingroup\$ @JonathonIrons Look at your other wirings: they're NOT in the same row (except maybe white, which looks like it should burn?) \$\endgroup\$ – Mars Jul 12 '19 at 5:36
    \$\begingroup\$ @Mars I think you need to look closer, they are all wired the same. \$\endgroup\$ – HandyHowie Jul 12 '19 at 8:29
