I want to emulate EEPROM over flash of STM32F103. Is there a way to use all free flash instead of the only page? How can I initialize starting point of my EEPROM emulation so that it would be after all sections? I tried to add section after .text like
.text: ...
.myvars :
. = ALIGN(1024);
KEEP(*(.myvars));
KEEP(*(.myvars*));
} > rom
and define variable as
__attribute__((section(".myvars"))) static const flash_storage Flash_Storage = {
    .magick = "1234567890absdef0987654321",
    .all_stored = USERCONF_INITIALIZER
but it doesn't helps me: I see some more data after this structure in binary dump.
UPD: the solution of this problem quite simple. The section .myvars should be after last section in ram, i.e. after .data!
  • \$\begingroup\$ Here's a link to ST's EEPROM emulation, in case you haven't seen it. There may be insights in their source code. \$\endgroup\$ – bitsmack Jul 10 at 18:58
  • \$\begingroup\$ @bitsmack, sounds funny, but I can't find sources of ST's EEPROM emulation. In the RM there's nothing about memory structure. \$\endgroup\$ – Eddy_Em Jul 10 at 19:11
  • \$\begingroup\$ Their website is strange, indeed :). Here's the software pack for STM32F103/105 microcontrollers. \$\endgroup\$ – bitsmack Jul 10 at 20:06
  • \$\begingroup\$ @bitsmack, all OK! I just add section .myvars after section .data and now all fine! Also I have an error: STM32F103 page size is 1024 bytes, not 2048. \$\endgroup\$ – Eddy_Em Jul 10 at 20:19
  • \$\begingroup\$ Great! Glad to know it worked :) Instead of updating your question, you should add your own answer! This will allow the database to work correctly, and we can also give you upvotes. :) \$\endgroup\$ – bitsmack Jul 10 at 20:24
The simplest solution of such problem is to put the section .myvars after latest section in ram. In my case it should be after section .data. The full linker file:
MEMORY
    rom (rx) : ORIGIN = 0x08000000, LENGTH = 128K
    ram (rwx) : ORIGIN = 0x20000000, LENGTH = 20K
ENTRY(reset_handler)
SECTIONS {
  .vector_table 0x08000000 :
    _sisrvectors = .;
    KEEP(*(.vector_table))
    /* ASSERT(. == _isrvectors_tend, "The vector table needs to be 84 elements long!"); */
    _eisrvectors = .;
  } >rom
  .text :
    . = ALIGN(4);
    _stext = .;
    *(.text*)
    *(.rodata*)
    . = ALIGN(4);
    _etext = .;
  } >rom
  .ARM.extab :
    *(.ARM.extab* .gnu.linkonce.armextab.*)
  } >rom
  .ARM : {
    *(.ARM.exidx*)
  } >rom
  .data :
    . = ALIGN(4);
    _sdata = .;
    *(.data*)
    . = ALIGN(4);
    _edata = .;
  } >ram AT >rom
  .myvars :
    . = ALIGN(1024);
    KEEP(*(.myvars))
  } > rom
  _ldata = LOADADDR(.data);
  .bss :
    . = ALIGN(4);
    _sbss = .;
    *(.bss*)
    *(COMMON)
    . = ALIGN(4);
    _ebss = .;
  } >ram
PROVIDE(_stack = ORIGIN(ram) + LENGTH(ram));
Here is the code.
