I have a multi meter I want to measure DC 1-50 milliamps which range I should select by the knob?
Also where I need to plug in 20A or mA?
    \$\begingroup\$ I am curious if you read the manual yet? \$\endgroup\$ – Transistor Jul 11 '19 at 11:10
    \$\begingroup\$ @Transistor And it is quite a short manual! With things like "The 20A range is not protected by a fuse and has a maximum 10A continuous current rating." that should be in read, blinking and with a loud buzzer... ;) \$\endgroup\$ – vangelo Jul 11 '19 at 11:11
Use the 200m setting from the orange section with an A with a solid and dotted bar above. You can find the manual for the meter here.
| improve this answer | |
  • \$\begingroup\$ I need to plug the red wire to 20A or mA socket ? \$\endgroup\$ – Tanvir Afzal Jul 11 '19 at 11:03
  • \$\begingroup\$ mA. Please take some time to read the linked manual. You can damage your device by connecting it wrongly. \$\endgroup\$ – vangelo Jul 11 '19 at 11:05
  • \$\begingroup\$ Thanks a lot for the quick help. Much appreciated. \$\endgroup\$ – Tanvir Afzal Jul 11 '19 at 11:06
  • \$\begingroup\$ mA and COM, see the manual. \$\endgroup\$ – Colin Jul 11 '19 at 11:06
