I am trying to simulate a simple inverter in verilog using modelsim 10.7 version. While compiling the code I am getting the -novopt error (error code 12110). As per user manual page 80; the -novopt argument is to be removed from vlog, vcom and vsim commands and from voptflow variable in the modelsim.ini file.
To remove the error, I set the voptflow variable to '0!' but could no find this argument for vlog, vcom and vsim commands. Pls. tell me how to go about solving the issue so that I dont get the error. I am attaching a snapshot of the error popup and my modelsim.ini file here.
Modelsim.ini file doenload link:
http://s000.tinyupload.com/?file_id=88953175349637767605
Thanks in advance.
  • \$\begingroup\$ Why are you using -novopt in the first place? \$\endgroup\$ – Dave Tweed Jul 11 '19 at 12:44
  • \$\begingroup\$ Thanks for the reply. I am not using the -novopt option. I just installed the tool and tried the first simulation and ran into this error.It is most probably set as a default option and I am not able to remove it. I just want to run verilog and systemverilog codes. Pls. help. \$\endgroup\$ – Arvind Gupta Jul 11 '19 at 15:39
  • \$\begingroup\$ Don't remember the GUI flow, but from command line you should be able to compile using vlog -work work file_name.v and then run vsim work.file_name for simulations. \$\endgroup\$ – rvkrysh Jul 12 '19 at 1:17
  • \$\begingroup\$ Thanks @rvkrysh for your response. I am new to the tool and hence looking for the GUI option. \$\endgroup\$ – Arvind Gupta Jul 12 '19 at 6:49
you should enable the vopt flow. you can do that by going to view >> properties >> VHDL >>> and check the "use vopt flow" option.
