I have capacitors C1 through C6 on my schematic, and if I type MOVE C2 into the command line it grabs that capacitor. But on the board created from my schematic, it is missing C2 and C3 and no other parts (that I have noticed). If I type MOVE C2 it says C2 does not exist. When I run ERC it says my board and schematic are consistent. I have no idea what to make of this, I can't find this anywhere online. Both capacitors in questions connect a node to GND and on the board layout the capacitor and connection to GND don't exist at all
  • \$\begingroup\$ I edited your question to only ask one question. If you want to ask about the other issue, you should post it as a new question. \$\endgroup\$ – The Photon Jul 11 '19 at 19:41
  • \$\begingroup\$ Do those capacitors have footprints defined? Any error messages when generating the netlist, or importing it into the PCB program? \$\endgroup\$ – Peter Bennett Jul 11 '19 at 19:59
I figured it out thanks to Peter Bennett's comment. I had used the SPICE symbol for two of my capacitors when I added a part instead of an actual device that has size specs, and those don't show up on the board.
