I have a solar charge controller which can charge 12volts batteries. I have two 12 volt batteries which are connected in parallel. I need to have 24volts output without using dc-dc step up converters. Can I connect two 12 volt batteries in both parallel and series? like first having a parallel then having a series connection with some Diodes to control the current/voltage flow. Is it possible? are there some best practices?
EDIT: goal is do charge/discharge the batteries simultaneously.
  • \$\begingroup\$ "like first having a parallel then having a series connection" could you clarify this? Is there a switch or control circuit that will select one of the operating modes: charging or discharging? \$\endgroup\$ – vangelo Jul 11 '19 at 20:05
    \$\begingroup\$ There's no easy way around this. Either you wire them in parallel and use a DC-DC converter to generate the 24V, or in series and use a converter to charge the second battery, or have a changeover switch or relay that would prevent simultaneous charge and output operation. \$\endgroup\$ – Phil G Jul 11 '19 at 20:09
  • \$\begingroup\$ You can charge in parallel then switch to use in series with what you have. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jul 12 '19 at 1:32
  • \$\begingroup\$ @SunnyskyguyEE75 That's the problem, I need to charge and discharge simultaneously. \$\endgroup\$ – Ata Mohammadi Jul 12 '19 at 8:49
    \$\begingroup\$ Then you clearly have proposed an unworkable solution. No PV specs for Voc, P,max, no MTTP controller, no 2V4 charger, no battery balancer and no educated research on these requirements. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jul 12 '19 at 11:57
On the face of it, not really unless you use switches to take the batteries offline while you charge them.
Now if you can use 2 chargers, and the chargers have a floating (ungrounded) output, you could connect each one across each battery. If the batteries are to be kept online ensure that the charger has current limiting and reverse-current blocking.
Or, use 1 charger and use a DPDT relay to switch the charger between each of the batteries in turn. But then you have to control the relay...
Or, eBay your 12V unit and get a dual voltage unit like this one: https://www.altestore.com/store/charge-controllers/solar-charge-controllers/pwm-solar-charge-controllers/xantrex-solar-charge-controllers-pwm/xantrex-c35-charge-controller-35a-12-or-24v-solar-charge-controller-p2069/
|improve this answer|||||
