I have a TCPSocket* object which holds a connection to a client. This object is passed to another object to send data back to the client:
    uint32_t count = 10;
    char message[4];
    message[0] = count & 0xff;
    message[1] = (count >> 8) & 0xff;
    message[2] = (count >> 16) & 0xff;
    message[3] = (count >> 24) & 0xff;
    client->send(&message, strlen(message));
When this part of the program is called, the following appears on the serial line, and no data is received by the client:
    ++ MbedOS Fault Handler ++
        FaultType: HardFault
        Context:
   R0   : 00000000
                  R1   : 10008000
                                 R2   : 00000004
                                                R3   : 2007C000
                                                               R4   : 10000914
        R5   : 00000000
        R6   : 00000000
        R7   : 10004330
        R8   : 10004320
       R9   : FFFFF435
                      R10  : 00000000
                                     R11  : 00000000
                                                    R12  : 00012AC1
        SP   : 10002AF0
        LR   : 0000D1A1
        PC   : 00005938
        xPSR : 21000000
        PSP  : 10002AD0
           MSP  : 10007FD8
                          CPUID: 412FC230
                                         HFSR : 40000000
                                                        MMFSR: 00000000
        BFSR : 00000082
        UFSR : 00000000
        DFSR : 0000000A
        AFSR : 00000000
        BFAR : 10008010
               Mode : Thread
                            Priv : Privileged
                                             Stack: PSP
                                                       -- MbedOS Fault Handler --
        ++ MbedOS Error Info ++
        Error Status: 0x80FF013D Code: 317 Module: 255
                   Error Message: Fault exception
        Error Value: 0x5938
        Current Thread: main  Id: 0x10002B48 Entry: 0xD7D7 StackSize: 0x1000 StackMem: 0x10001B48 SP: 0x10007F88
                                                          For more info, visit: https://armmbed.github.io/mbedos-error/?error=0x80FF013D
     -- MbedOS Error Info --
Everything is in one thread so I cant see what could be causing this.
These are the relevant parts of the program:
main:
// Network interface
EthernetInterface net;
TCPSocket listener; //listens for incoming connection requests
TCPSocket* client;
CommandProcessor commandProcessor(client);
int main(){
int remaining;
    int rcount;
    char *p;
    char *buffer = new char[16];
    nsapi_size_or_error_t result;
    int n = net.set_network("192.168.1.103","255.255.255.0","192.168.1.2");
    pc.printf("\n Success? %d\n", n);
    net.connect();
    listener.open(&net);
    listener.bind(3045);
    listener.listen(1);
    client = listener.accept(NULL);
    client->set_timeout(1000);
    led1 = 1;
    while(1) {
        int remaining = 16;
        int rcount = 0;
        p = buffer;
        while (remaining > 0 && 0 < (result = client->recv(p, remaining))) {
            p += result;
            rcount += result;
            remaining -= result;
        if (remaining == 0) //full message received
            commandProcessor.process(buffer);
CommandProcessor:
CommandProcessor::CommandProcessor(TCPSocket* client)
    this->client = client;
void CommandProcessor::process(char* message)
    switch(message[0]) { //Command is first byte of message
    case 0x3: {
     uint32_t count = 10 ;
    char* message = new char[4];
    client->send(message, sizeof(message));
[Referring to initial question where message was defined as char message[4];]
  1. message[] is being put on the stack. By the time the TCP stack comes to send the data is the stack still valid?
  2. strlen is not the way to determine the length of something that is not a string! Use sizeof(message) instead.
  3. Check the lifetime of the TCPSocket object as well.
  • \$\begingroup\$ Of course, send doesn't necessarily send the data by the time the send function has returned, does it? I'll make some changes and let you know. \$\endgroup\$ – 19172281 Jul 13 at 14:14
  • \$\begingroup\$ Unfortunately, that hasn't resolved the issue. \$\endgroup\$ – 19172281 Jul 13 at 14:18
  • \$\begingroup\$ The TCPSocket object persists for the duration of the program. It is declared in the main file. \$\endgroup\$ – 19172281 Jul 13 at 14:45
  • \$\begingroup\$ Can you post the whole program, cut down to the bare bones that show the problem? \$\endgroup\$ – srl100 Jul 13 at 14:46
  • \$\begingroup\$ The program is quite large so I'll edit out all the irrelevant stuff and post here \$\endgroup\$ – 19172281 Jul 13 at 14:50
