Looking into the MAX999 datasheet I can not figure out how to utilize information given for the Vih and Vil
Logic-Input High --- Vih --- (Vcc/2 + 0.4) min
Logic-Input Low  --- Vil --- (Vcc/2 - 0.4) max
The rest of datasheet says nothing about inputs' ability to be configured as logic inputs - it is the output which is logic level. What is the purpose of this information then?
It's for the logic inputs: SHDN - shutdown; and LEA - Latch-Enable Input -
When SHDN is high, the MAX961/MAX963/MAX964/MAX997 is shut down.
The MAX961/MAX963 include internal latches (ie the LEA) that allow storage of comparison results.
The MAX999 doesn't have any of these logic inputs.
| improve this answer | |
    \$\begingroup\$ I hate when they overload the datasheet with many parts. It's not like it costs anything to print a datasheet. \$\endgroup\$ – D Duck Jul 13 '19 at 23:09
    \$\begingroup\$ it is easier for a manufacturer to maintain one datasheet for a family of very similar parts, though. Particularly as they may all use the same silicon design in different packages and/or with laser trimmed variances. So you can see their predicament if you've worked on documentation in similar situations. Doesn't bother me, personally. \$\endgroup\$ – TonyM Jul 14 '19 at 7:10
  • \$\begingroup\$ @TonyM This might have been true in the past but in these days with databases and software etc. \$\endgroup\$ – D Duck Jul 14 '19 at 8:40
    \$\begingroup\$ oh, forget the past, I'm describing today :-) Try maintaining this stuff, loads of documents are a big workload. \$\endgroup\$ – TonyM Jul 14 '19 at 15:15
