I'm not sure if this post belongs here or in another community but here we go. I'm working with Eagle cad (pcb) and i'm looking through the libraries and I couldn't find a single MICRO b usb connector. I found a MINI b connector but I truly require a MICRO b connector for my design. Has anybody found one? I need one specifically for this Connector
    \$\begingroup\$ Create your own library then. :-) It's not hard. Do check the Sparkfun Eagle library though; they've got a bunch of stuff there, microUSB most likely too. \$\endgroup\$ Jul 15, 2019 at 23:51
    \$\begingroup\$ This kind of question is better suited for our EE.SE chat. \$\endgroup\$ Jul 15, 2019 at 23:53
    \$\begingroup\$ You really should almost always make your own footprint for connectors like this. Every vendor has their very own mounting scheme so the footprints are always slightly different. \$\endgroup\$ Jul 16, 2019 at 0:17
    \$\begingroup\$ I agree with @LosFrijoles. I always make my own libraries. You won't be sorry that you did. \$\endgroup\$
    – DerStrom8
    Jul 16, 2019 at 1:14
    \$\begingroup\$ @Brethlosze Thank you for the link, and to the rest does anybody know how to get started with making my own libraries? \$\endgroup\$ Jul 16, 2019 at 13:50
I found this one online that seems to be very similar to the one you posted. I'm testing it against the ones I can source here locally too:
https://github.com/snakeye/eagle-lib/blob/master/connectors/microusb.lbr
If you need ones with surface mounted supports instead:
https://github.com/dvdnhm/Maker-Tools-Eagle-Libraries/blob/master/MicroUSB.lbr
I think these two should fit the common ones you find in the stores.
  • \$\begingroup\$ Thanks, this still helps even tho this thread is 5 months old \$\endgroup\$ Jan 7, 2020 at 14:15
