what i am trying to achieve to be able to duplicate/recreate the infrared signal of my remote control using my arduino.
The arduino has a already a library for this, unfortunately it doesn't seem to support the board that i am going to use the arduino mkr1000. The library has a recieve that makes me able to see the data, but the function for transmitting it back is not working.
So this makes me resort to creating a function for sending myself. I know that the remote i am using uses and NEC infrared transmission protocol. So i looked at its specs.
according to it:
- a 9ms leading pulse burst (16 times the pulse burst length used for a logical data bit)
- a 4.5ms space
- the 8-bit address for the receiving device
- the 8-bit logical inverse of the address
- the 8-bit command
- the 8-bit logical inverse of the command
- a final 562.5µs pulse burst to signify the end of message transmission.
What i dont understand is, what is this address and command.
unfortunaly i do not have an oscilloscope inorder to probe my remote to confirm some hypothesis. What i have though is the output of the serial monitor the arduino upon recieving the signal.
Encoding : NEC
Code : 2FD807F (32 bits)
Timing[67]:
+9200, -4500 + 600, - 550 + 600, - 550 + 600, - 550
+ 600, - 550 + 550, - 600 + 550, - 550 + 600, -1700
+ 600, - 550 + 600, -1700 + 550, -1700 + 600, -1700
+ 600, -1700 + 550, -1700 + 600, -1700 + 550, - 600
+ 550, -1700 + 600, -1700 + 550, - 550 + 600, - 550
+ 600, - 550 + 600, - 550 + 600, - 550 + 550, - 600
+ 550, - 550 + 600, - 550 + 600, -1700 + 600, -1700
+ 550, -1700 + 600, -1700 + 600, -1700 + 550, -1700
+ 600, -1700 + 600
unsigned int rawData[67] = {9200,4500, 600,550, 600,550, 600,550, 600,550, 550,600, 550,550, 600,1700, 600,550, 600,1700, 550,1700, 600,1700, 600,1700, 550,1700, 600,1700, 550,600, 550,1700, 600,1700, 550,550, 600,550, 600,550, 600,550, 600,550, 550,600, 550,550, 600,550, 600,1700, 600,1700, 550,1700, 600,1700, 600,1700, 550,1700, 600,1700, 600}; // NEC 2FD807F
unsigned int data = 0x2FD807F;
From the output can we point out which is the address and which is the command? so that i will be able to create a code for it
