I have a problem with ground Copper pour for the PCB. I'm using EasyEDA.com to designing my PCBs.
But because i usually make my PCB directly without Drawing its schematic so i can't make the ground Copper pour because there are no GND detected by the system.
So i'm wondering if there are way to Copper pour without drawing the schematic?
Following image just an example:
    \$\begingroup\$ Such a simple design - why not make life easier for yourself and start from a schematic like other any other design? \$\endgroup\$ – CrossRoads Jul 18 at 13:43
You can change the NET label, for every pad you want to connect to say.. GND :) Then you can change to pad type if it's a through hole component to attach it to the ground plane. Example
