Im designing battery powered application and need reverse polarity protection.
My system specs: 4.5v(3x AA batteries) in and system running on 3.3v. Im using MCP1711T-33I/OT LDO to convert 4.5v to 3.3v. My system will take about 50 milliamps maximum. Therefore i can't obviously use any diodes since voltage drop and power waste will be too big. I read some threads and people tend to suggest P-channel MOSFET. I was looking for low rds(on) MOSFETS and all their packages seem so huge. Like this one:
http://www.farnell.com/datasheets/2049687.pdf
Size isn't too big problem though(sot23 package would be perfect though). Can you suggest me anything else than P-channel MOSFET? If not, can you suggest me some decent P-channel MOSFET for my needs? Thanks in advance.
  • \$\begingroup\$ Are you seriously saying 3 mohm is huge? What type of wires do you use to connect these 3 AA batteries? Superconducting ones? \$\endgroup\$
    – Huisman
    Jul 20, 2019 at 16:53
  • \$\begingroup\$ @Huisman He means package size \$\endgroup\$
    – DKNguyen
    Jul 20, 2019 at 19:44
  • \$\begingroup\$ @DKNguyen I wonder... they refers to the rds(on) in the sentence. Moreover: "Size isn't too big problem though" \$\endgroup\$
    – Huisman
    Jul 20, 2019 at 19:47
  • \$\begingroup\$ @Huisman I think he means he can deal with physical size, he just doesn't want to because it seems inappropriate for 50mA. \$\endgroup\$
    – DKNguyen
  • \$\begingroup\$ Yes, DKNguyen is right. Sorry for the confusion. I made up that sentence pretty badly. By saying huge i meant indeed package size and yes package size isn't too big problem, but it's huge for 50 mA in my opinion. It's power ratings are way over what i need. \$\endgroup\$
    – Mini Tamm
    Jul 20, 2019 at 20:00
4 Answers 4
If you are really concerned about voltage drop and power waste, I think you'd better focus on the MCP1711.
It is dissipating the difference between input voltage and output voltage so, 1.2 V * 50 mA = 60 mW at most.
Any RDS(ON) up to 1 Ω waists at most (50 mA)2 * 1 Ω = 2.5 mW.
I'd suggest to replace the MCP1711 by a high efficient step-down converter (next to using the P-mosfets suggested by others for polarity protection).
  • \$\begingroup\$ Yes, i just realized that myself too. Just in case i will ask is DMP2100U-7 MOSFET decent? I have burned down some MOSFETS in the past since i couldn't choose the correct one(farnell.com/datasheets/1669947.pdf). \$\endgroup\$
    – Mini Tamm
    Jul 20, 2019 at 20:48
  • \$\begingroup\$ Also just to be sure, will MCP1603/B/L be better choice? farnell.com/datasheets/1669947.pdf \$\endgroup\$
    – Mini Tamm
    Jul 20, 2019 at 21:02
  • \$\begingroup\$ @MiniTamm Yes, DMP2100U-7 is a good choice if it is for personal use (for product development it's not recommended for new design, use DMP2045U) \$\endgroup\$
    – Huisman
    Jul 20, 2019 at 21:21
  • \$\begingroup\$ And the MCP1603/B/L looks a nice candidate too (I briefly looked at it) \$\endgroup\$
    – Huisman
    Jul 20, 2019 at 21:36
With RDS of say 1 ohm you would have 50mV drop. This drop reduces the amount of energy you can drain from the battery a little, before the voltage drops too low, but otherwise it doesn't effect your system. Power loss in the RDS doesn't matter because you use a linear regulator so total power loss doesn't change. So I'd say you can easily find good enough MOSFET even in SOT23 package.
  • \$\begingroup\$ Im sorry, but what you mean by: Power loss in the RDS doesn't matter because you use a linear regulator so total power loss doesn't change.? \$\endgroup\$
    – Mini Tamm
    Jul 20, 2019 at 20:14
  • \$\begingroup\$ A linear regulator works so that it adjusts its resitance so that it "burns" the excess voltage to achieve the correct output voltage. If you have some series resitance with a linear regulator it does part of the "burning". As a result the total power dissipated in the regulator and the series resistance is the same that the linear regulator would dissipate alone. \$\endgroup\$
    – TemeV
    Jul 20, 2019 at 22:40
Even ~500mOhm RDSon is plenty low for this.You are searching for too low an RDSon for your application. I use the IRLML6402 (65mOhm) or IRLML6302 (600mOhm) because that's what I like. It makes little difference at 50mA. You'll notice a 30mV drop as much as you will notice a 3mV drop.
I have used Si2305 which works great. Check it out. It dropped <0.2v @150mA
