I have to measure a DC voltage and an AC voltage around 100V. I found the circuit with an AD629 and one OP177.
I simulated everything in Spice and it works fine, at least in the simulation. In reality the power supply (V_IN) is isolated. It doesn't share a ground with the rest of the measurement circuit. V_OUT should be converted by an ADC which doesn't share a ground with V_IN.
Is it still possible to use this circuit because of the high input impedance? If so should pin 1 (Ref-) of the AD629 connect to the V_IN ground or to the shared analog ground with the rest of the circuit?
And do you think there are problems when measuring DC voltages instead of AC voltages? In the simulation it doesn't matter.
